Home -> Forums -> Construction -> Foundation -> New column footage and pillar very next to the wall of existing building
Tue Oct 14, 2014Total posts : 4
Robert
Robert
Topic: New column footage and pillar very next to the wall of existing building
My house 20 feet width and 20 feet length is already constructed
But there is no kitchen, so planning to construct kitchen backside
Of the house, free area is of 20 feet width and 8 feet length,
I want to do this with columns and beams, my question is,
How to make the column very next to the existing wall since there is
A column footage of my already built house, how to lay new footage. Please your advice.
Robert
Wed Oct 15, 2014Post  #1
Go for RCC raft and RCC wall. get it designed.you can constructe
Wed Oct 15, 2014Post  #2
Robert
Robert
Post subject: Will there be more cost difference for rcc raft ...
Thanks Sanjay,
Will there be more cost variations for rcc raft when
Compared with column footing, as on reading about raft footing, I found its if more number of beams as matrix, if so is there any other way of foundation?
But I need columns upto roof,
Thanks in advance for your reply
Thu Oct 16, 2014Post  #3
Please consult with an engineer or an experienced civil Contractor.
Thu Oct 30, 2014Post  #4
Rachael Suggs
Rachael Suggs
Post subject: Steel Buildings Colorado Springs
Outdoor kitchen is a great idea to enhance the look and viability of your house. They will give a very modern and fresh look to your house and will especially be of great use when you wish to enjoy the nice weather outside and cook simultaneously.
2525
15360
2nd floor construction
2473
need your guidance
Last answer on 4/22/2012 2:58:55 AM. by S L Gupta (Civil Engg). Forum started by ketan jayswal
2464
I am building a 2 storeyed building. I have a Main wall which is adjacent to a existing house.
Last answer on 4/1/2010 10:32:47 AM. by Manoj. Forum started by pkarkeyan
8850
Last answer on 10/15/2014 1:52:38 PM. by SANJAY DUSANE. Forum started by Ambuj
2557
1967
while building an extension building next to old one the ceilings were kept apar
Last answer on 8/20/2011 2:20:45 AM. Forum started by D.Ramachandran
1699
How should be footing net for column adjacent to existing wall
Last answer on 6/3/2017 3:04:50 PM. by S L Gupta (Civil Engg). Forum started by Surinder Singh
2694
2321
2095
in concrete piller using more cement sand than20 mm jelly what is the result will be?
Last answer on 5/19/2015 9:17:17 PM. by JAI PRAKASH. Forum started by manja nayka k r
2537
RCC column (pillar)
2101
2037
construction of second 7 third floor
Last answer on 1/2/2013 11:45:31 AM. by S L Gupta (Civil Engg). Forum started by kiran kumar 3k
2119
construction process
Last answer on 8/19/2014 11:40:26 AM. by S L Gupta (Civil Engg). Forum started by Bhuwan
3795
Last answer on 11/15/2016 1:51:43 AM. Forum started by K Srinivasan
4939
COLUMN AND STEEL DESIGN
2684
Pillar
2140
Curing urgent
2372
structure work
5166
Pillar foundation
2202
new house
2821
building a house
1991
Construction Agreement
3089
Foundation
2272
Foundation
1476
10047
3660
Foundation
2115
Structure proof checking
2558
Foundation design
2459
2467
Saria and cement
3656
Wall Thickness
2678
3179
13267
Steel Type
Brick Pillar
Happy
Happy New Year 2009
Orientation
Orientation of Building
Canvas
Canvas Wall Art
