Mon Aug 15, 2011 | Total posts : 2 |
| Topic: New house design
Hello from Kolkata: liked this site & got registered; however, felt like the contents could be further organized etc.
So..I'm just about to get a land around 2513 sq. ft; 15' road on the east side and 9' passage on the north side. The shape isn't exactly a square - E - 44'11" W - 45'8" N - 63'9" S - 47'10"
Plan to construct a great looking house on it with a small garden and car space etc; haven't talked to an architect just yet but need some advice on how the 'leftover land' should be utilized after taking a out a perfect square from the total area. Also, without knowing further details, could you say, typically what could it cost me to make the structural design, interior design, electrical & plumbing design. Plan to have a 3-4 storied foundation, and 1 story would be built for now.
On a side note..impressed by the posts of Mr. S L Gupta on the forum.
Thank you.
Tue Aug 16, 2011 | Post #1 | Gunjan Utraja
Join date: Dec 2007 | Post subject: GharExpert services details
Dear Mr. Gupta,
Thank you for contacting GharExpert for construction related services. For proceeding it further, just read about the GharExpert service given below:
Please look at the services offered by GharExpert:
A. Architectural Drawing Services – Drawings Only
A.1. Architectural Services: Architectural service of the house which includes the following: · Floor plans · Basement drawing · Basement details and waterproofing solutions
A.2. 2D Elevation:
First Phase · Front Elevation · Rear/Side Elevation · Boundary Wall · Exterior Gate Design · Sections Second Phase · Terrace plan · Internal details such as Staircase ,mumty etc. · Door / window Schedule A.3. Structural Services: This service will include the following: · Foundation details o Foundation Plan o Footing Schedule o Column Schedule o Detail of Columns and Walls with steel arrangement o Details of Plinth beam · Structural drawings showing the beam and slab reinforcement details. A.4. Electrical Services:
This service will include the following: · Drawings showing the position of electric fan, exhaust fan, tube light, bulb, power plug and switches etc. · Position of inverter and electrical motor pump etc. · Layout showing the whole conduting and wiring network. A.5. Plumbing Services: This service will include the following: · Layout drawing showing the position of washbasin, sink, W.C. seats, shower, bathtub and overhead tank etc. · Plumbing drawings which will include the network of laying of the pipes.
A.6. Vastu Services: For vastu plans, vastu experts work with our architect to make a vastu compliant plan. Further iterations would be done till construction completes.
A.7. 3D Elevation: · Front Elevation · Rear/Side Elevation · Boundary Wall · Exterior Gate Design
For vastu plans, vastu experts work with architect to make a vastu compliant plan
B. Please Look at the packages we offer for Interior Design :
Our design portfolio will include the following drawings.
1. Layout drawings.
2. Wall elevations of all rooms.
3. Ceiling drawings of all rooms.
4. Flooring drawings of all rooms.
5. Electrical layout drawings.
6. Details wherever required.
7. Wardrobe designs or storage drawings where ever applicable.
8. Design specifications which will include the color options, texture styles etc.
9. Toilet detail drawing for all toilets.
10. Kitchen layout drawings
11. Suggestions on type of furniture, furnishings and artifacts.
12. Door and window details.
C. Detailed construction cost estimate It is a step by step calculation of the material and labor required to complete a construction project. This document is prepared after analyzing the architectural plan of the building and has all details about the cost and material involved. For example, it will give you the exact quantity of cement bags, bricks, sand, steel and other raw material required and the prices in your area.
We have service for the construction cost estimate which would give you the brick by brick cost calculation. Our detailed cost estimate pricing is given below: Up to 2000 sq.ft area= Rs.2.50 per sq.ft. From 2001 to 5000 sq.ft area= Rs.2.00 per sq.ft. From 5001 to 10000 sq.ft area= Rs.1.50 per sq.ft. Above 10000 sq.ft area= Rs.1.00 per sq.ft. We will take almost 15 business days to prepare the detailed cost estimate. We will supply you the document containing step by step calculation of the material and labor required to complete a construction project. This document is prepared after analyzing the architectural plan of the building and has all details about the cost and material involved. Everyone can save upto 10% of the construction cost which can be a saving of Rs. 50 to Rs.100 per square feet.
For preparing the detailed cost estimate, We need additional documents from you:
1. What type of flooring are you planning to use in all the rooms? 2. Which type of frames is being used for doors and windows? 3. Which type of shutters and wood is being used for doors and windows? Would it be deodar wood, hollock wood, teak wood etc. 4. What material are you planning to use on Bathroom and Kitchen Walls? 5. What type of finishing will be used for Exterior walls? 6. Do you have exterior elevation design and structural drawings provided by your architect? GharExpert can provide you a detailed cost analysis for your project that will help you save a lot of money.
We are also working on commercial and Institutional project. Click on the link given below to view the sample of those buidlings:
http://www.gharexpert.com/articles/Architecture-2160/Hire-GharExpert-your-Institutional-Commerc-0.aspx
Wed Aug 17, 2011 | Post #2 | SGupta
Join date: Aug 2011 | Ok, found the reply was to much generic whereas a specific question was asked; what do I had to do with other funny stuffs including commercial and institutional projects. Thanks anyway.
Layout and House Plans-Construction Questions (39) | |
Articles that might interest you! | | Planning a House Once the architect has given his design options, it becomes necessary to select one and start working on it. | | Happy New Year 2009 GharExpert.com wishes you a Happy New Year. It’s a special occasion to celebrate and dance with friends and guests enj.. | | Ceiling Design- New Ceiling Design for 2012 Ceiling design ideas can change the overall look of the room. Look at the new collection of ceiling design that gives .. | | Orientation of Building To get maximum ventilation and natural light in your house, make sure the building is properly oriented. Orientation o.. | | Happy New Year 2011 Wishes: Dream House Wallpapers from Gharexpert GharExpert.com launched 2011 wallpapers.Check them out and let us know how they look.In order to setup these pictures a | | Building New Home V/S Buying Builder Flat Buying a builder’s flat may be costlier for you rather than building a new home. But if you plan to make your own, you.. | | How to design a house on theme Theme designing is slowly but steadily picking up steam. Designers today are very particular about the 'idea' behind a s | | Bedroom Makeover Do you want your bedroom looks pretty and charming? If yes, it is the right time to renovate the your bedroom and twi.. | | Layout of Building The real meaning and purpose of setting out (layout) is to transfer the plan, length and width of its foundation on th.. | | Installation Precautions for Wooden Flooring Installation Precautions are compulsory to make wooden flooring long lasting. If You do not follow these precautions, .. | | What are various types of glasses used in doors? Types of glasses used in doors-Clear window glass, Plate glass, Prism glass, Quartz glass, Processed glass....... | | What are advantages and disadvantages of folding doors? Advantages of folding doors- Easy to install,washable, durable, superior sound damping. Disadvantages-sensitive to har.. | | What are various designs available in wooden doors? Designs available in Wooden doors..... | | What is standard size of internal folding doors? Size, Thickness and Weight of Internal Folding Doors....... | | What affects the life of doors? What can we do to increase the life of the Wooden doors? Tips to increase the life of Wooden doors.... | | What is the standard size of frame for Plastic/PVC doors? Plastic Door frame size carrying one or two shutters...... | | What are various frames recommended for Plastic/PVC doors? Frames for Plastic Doors.......... | | Which place is appropriate for sliding door? Appropriate places for sliding doors-Bathrooms, Backyards, Commercial structures........... | | What are various frames recommended for glass doors? Frames for Glass Doors-Wooden frames, Steel frames, Aluminium frames...... | | Which place is appropriate for folding doors? Appropriate places for folding doors-Homes, Offices, Guest rooms, gives attaractive and stylish look........ | | What are the various accessories recommended for folding doors? Accessories for folding doors- Door Handles, Door Fasteners,Door Viewers....... | | What affects the life of doors? What can we do to increase the life of the Plastic/PVC doors? Tips to increase the life of Plastic doors.... |
