Home -> Forums -> Construction -> Cement Plastering -> OPC and PPC cement
OPC and PPC cement
Fri Jun 24, 2016Total posts : 1
Meda Kameswara Rao
Meda Kameswara Rao
Topic: OPC and PPC cement
Dear Sirs,
I am constructing new house. What will be result if I use PPC cement for brick wall construction and OPC for plastering? Thanks
Sat Jun 25, 2016Post  #1
Dear Rao
       Types of Cement
For engineering purposes, there are many types of cement but in general, ‘Ordinary Portland Cement’ (OPC) which is available in three grades should be used for house construction
33 Grade Ordinary Portland Cement
This ordinary 'Portland' cement is used maximum in the country. It is more suitable cement for masonry and general concrete works where the members are not taken to very high stresses. It is not suitable where ‘Sulphate’ is in the soil or in the ground water.
43 Grade Ordinary Portland Cement
43 grades of cement are used where high early strength in 1 to 28 days range is required. These days the ‘Structural Engineers’ propose these cements mainly for RCC works where a member takes high tensile stress.
53 Grade Ordinary Portland Cement
53 grades of cement are used where high early strength in 1 to 28 days range is required. These days ‘Structural Engineers’ propose these cements mainly for RCC works, where a member takes high tensile stress.
Caution in the use of 53 grade cement in construction:
The strength of 53 grade cement does not increase much after 28th day because of early gain while 33 grade cement continues to gain strength after 28th day.
In addition, due to faster hydration process, the concrete releases heat of hydration at much faster rate initially and release of heat is the highest in case of 53 grades. The heat of hydration being higher, the chances of micro-cracking of concrete is much greater. Thus during initial setting period of concrete, the higher heat of hydration can lead to the damage of micro-cracking within the concrete which may not be visible at surface.
This cracking is different from shrinkage or cracks which occur due to faster dryness of concrete in windy conditions. The situation can be worse when we tend to increase the quantity of the cement in concrete with a belief that such increments are better for both strength and durability of concrete.
Thus it is very essential to be very careful in advance that higher grade cement specially GRADE 53 SHOULD be used only where such use is warranted for making the concrete of higher strength and also where good quality assurance measures are in place by which proper precautions are taken to relieve the higher heat of hydration through chilling of aggregates or by proper curi
2695
2004
PPC and OPC cement
4209
Selection of cement ..
2264
Cement selection
25607
CURING TIME FOR RCC ROOF
2307
Cement selection
Last answer on 10/31/2012 10:53:57 AM. by amzad. Forum started by amzad
1740
About Cement
Last answer on 2/3/2014 1:32:10 PM. by S L Gupta (Civil Engg). Forum started by AAYUSH
23818
Last answer on 2/17/2021 4:49:34 AM. by S L Gupta (Civil Engg). Forum started by vinu
3037
use of tmt bar
4371
Ready Mix Concrete
2421
start construction Steel use
3791
1282
2527
RCC Slab -Curing
2492
Used M15 (1:2:4) mix ratio with PPC cement for casting ground floor house roof slab
Last answer on 2/21/2017 12:28:02 PM. by S L Gupta (Civil Engg). Forum started by vinu
1763
1457
1659
Last answer on 7/15/2017 12:48:17 AM. by S L Gupta (Civil Engg). Forum started by Frank lun ngaihte
1923
2929
Plaster
2780
Plaster work
3047
Plastering
1925
2004
PPC and OPC cement
11298
1871
suggest for exterior
7004
9157
2157
2012
coarse aggregate
1826
Nice
2437
Gypsum Plaster Vs S/C Plaster
2173
Outer Plaster
2996
2735
putty work on walls
2236
2827
2033
Cement Concrete Raw Material
Read points should be kept in mind while collecting raw materials for cement concrete in construction work.
Types of Cement
