Offset between Concrete Slab and Wall
Wed Nov 26, 2014
Harinath P
Topic: Offset between Concrete Slab and Wall
Friends, We are constructing our home in Bangalore. Constructing slab upon wall.
We finished our Concrete slab, Now after curing we removed the centering and checked that there is an offset of 6 inches between wall and concrete. We had not planned any beam there.
Please help me by directing your valuable answers to solve it.
Thu Nov 27, 2014
Dear Harinath
Your query is not clear, how the offset seen after removing shuttering. Clarify the problem in drawing.
Thu Dec 04, 2014
Please add pictures.
2276
swarup chakraborty
1767
vishal Thakur
1460
vishal Thakur
3470
Cost of concrete walls
Ar. Manoj Ralen
Ankur Kothari
3082
Last answer on 2/25/2014 6:35:09 AM. by
manish
jagminder
2335
Related to Sunken Slab
Last answer on 10/25/2015 8:30:24 PM. by
SOUNAK SAMANTA
2677
Last answer on 10/12/2014 8:53:52 PM. by
nith_piyush
1067
Last answer on 7/4/2020 3:50:38 AM. by
Surinder Singh
1071
building 8" wall onthe slab will effecet the on the outer side
Last answer on 7/4/2020 2:02:31 AM. Forum started by
Badhavath Rajeshwar
4058
Last answer on 7/26/2012 12:16:09 PM. by
sanjay kumar makhija
13781
concrete slabs or wooden slabs for wardrobe
Last answer on 7/3/2020 10:20:22 PM. by
sam_m400
pallubc2
2153
4012
labor rate for RCC work
Last answer on 7/28/2020 1:27:06 AM. by
ringwang
ringwang
6471
Last answer on 4/5/2018 12:39:19 AM. by
Sanzana Hosen
2526
Last answer on 5/16/2021 2:27:15 PM. by
bhaskar
1288
I want to build bedroom loft of 2 feet extend from wall. The side walls are 11'
Last answer on 7/4/2020 4:18:19 AM. by
Surinder Singh
Surinder Singh
2559
Last answer on 10/15/2017 1:22:37 AM. by
gautam kumar
gautam kumar
895
My home is 3 floor, ground Plus 2 floor. But built up with 4" brick walls along
Last answer on 7/3/2020 9:43:54 PM. Forum started by
Rohit Kumar
5862
Last answer on 11/13/2016 12:55:24 AM. by
srikanth
5812
Rakeeb Rathor
3793
Pandu
9885
nasad
2670
Sreedhar
4628
ani
4143
Anamika
2866
lio
ringwang
R.Roy
5008
MANISH
3657
Arvind Bhaskar
premkumarlen
1865
carmenjames
r.n.misra
2801
Sharath Kurva
Sharath Kurva
2610
gk
2374
Adriano Peres
vamsi
2464
nuksung
2638
dayal
1808
TUNDE
3608
ragha
6254
suba
Concrete Decor
Garden Path Ideas
Concrete Mix Ratio
Reasons of dampness
