Home -> Forums -> Interior -> Home Improvement -> Options to redo walled tiles
Sun Sep 11, 2011Total posts : 2
Gary
Gary
Topic: Options to redo walled tiles
Hi guys,
To introduce I am Gary from Mumbai. I have lately purchased a (7th floor) top floor flat in a residential complex. This is a one room kitchen flat and hence you might understand how important the main room is to me and my fiance.
The previous owner has put bathroom tiles on the walls of the living room, as he had some seepage issue (from the terrace) as the flat is on top floor. Good as the previous owner's intentions were I am now stuck with my living room looking like a bathroom.My fiance and myself are looking for ways to correct this.
yes we have an issue on how to improve this keeping a tab on costs.
I have spoken to a number of people and they have all given me varied opinions..
  1. Some people told me about breaking the tiles while most have told me this will open up the seepage and is best kept as it is.Now on removing the tiled look also i have got varied opinions.
  2. one cross section of people have told me to go for wallpaper. when i visited a wallpaper supplier he told me that the tile joints will have to be filed with 'Lambi' and then we can put up the wallpaper. however the joints will be seen even after that (i can live with the joints boundaries being seen as long as the tiles are not seen).
  3. Now someone else told us to go for areldite + sand treatment and then pup plaster of paris . post that we can either use wallpaper or paint the walls. the disadvantage is that POP will take time to dry in the monsoon.
  4. we have also been advised to go for POP sheets drilled into our tiled walls and then use Wallpaper over it or paint it. Disadvantage is drilling tiled walls and chance to damage concealed wiring.
  5. we can go for Cement sheets drilled into tiled walls and then use wallpaper or paint.Disadvantage is drilling tiled walls and chance to damage concealed wiring.However it is more sturdy than POP.
  6. We can go for Gypsum sheets drilled into our tiled walls and then use wallpaper or paint.More sturdy than POP but less sturdy than cement sheets
  7. keep the tiled as it is (we really don't want to do this)
I am not keen on points 1 and 7 as they are extremes.
Please help me my expert friends in finding a solution to my dilemmas and tell em the right way. which is the best way to get out of this mess and make my living room beautiful ? also is there some other solution I haven't thought about yet????
Tue Sep 20, 2011Post  #1
Dear Gary
     I am in view that the tiles laid on the wall may be ceramic tiles or glazed tiles. These types of tiles have zero joint. The best and economical solution is to make putty with synthetic enumal paint and applied on joints which have no problem of drying and you can paint the tiles after 6 to 8 hours. You may do the syntetic enumal paint not the oil bound distemper or emulsion paint. The shade and color should not be light.
Sun Sep 25, 2011Post  #2
Gary
Gary
Dear Gupta sir,
Thank you so much for your answer. Alas after not getting answer for a week I took my decision which was going for Point 3. i.e. areldite + sand treatment and then pup plaster of paris
Now that I have aready doen it I will stcik to the decision. However I want to realy thank ou for taking tiem out and ansering my quiery. You answering in the forms is what make Gharexpert a trusted website :)
Gary
1745
please let me know on the roof tile is better or marble is the better option . p
Last answer on 6/20/2016 11:35:02 PM. by Purvi Panchal. Forum started by Krishna
2616
Exterior Walls
2498
removing screed on brick tiles
Last answer on 7/13/2020 10:37:59 PM. by JAI PRAKASH. Forum started by chander
2565
2776
Is this paint or tiles on wall?
Last answer on 3/30/2011 9:13:41 PM. by Mohini Sharma. Forum started by rupali
2990
details about wall claddings, tiles & all including its rate
Last answer on 10/8/2020 12:45:36 AM. by S L Gupta (Civil Engg). Forum started by laxmi
2331
2082
i need picture of wall tiles for my teenage boy's room
Last answer on 2/17/2012 8:06:03 PM. by S L Gupta (Civil Engg). Forum started by ayushi sharma
2501
Porch Swings
Last answer on 3/17/2012 5:07:37 PM. by mourougappane. Forum started by Manish
3713
exterior walls
1850
can i use vetrified floor tiles (600 x 600 )for my hospital wall( dado )instead
Last answer on 1/29/2011 1:47:18 PM. Forum started by vikram khot
2350
Need Suggestion
4764
2685
Last answer on 4/26/2021 10:00:27 AM. by mohamed. Forum started by Sanjeev Thakur
2572
these square share boxes are tiles or paint on the wall??
Last answer on 3/30/2011 9:10:42 PM. by Mohini Sharma. Forum started by rupali
12580
can we paste the sunmica on the newly built wall without wood base as we r pasti
Last answer on 7/4/2020 2:04:05 AM. by ravi at Dalmia. Forum started by veeraraghavan
9157
3076
5325
Last answer on 10/8/2015 1:01:18 AM. by JAI PRAKASH. Forum started by nancy
2355
Refinish a Vinyl Floor
2521
Introduction
1088
Home appliances
2370
2964
layout plan
2182
Window Curtains For Home
3426
Reg: Interior design software
4764
2718
Living Room Decoration Ideas
2238
2034
2212
floor tiles
797
Online dating
2543
4041
Paint vs Wallpaper
2528
Design for a pooja room
9541
Wall Putty and primer
Straight Drop Awnings
2754
Kids Room Theme
2019
sapty tank
Tiles
Tiles for Bathroom
Tile
Designing
Types of Windows and Door options in uPVC
Cooper
Canvas
Canvas Wall Art
