Home -> Forums -> Construction -> Cement Plastering -> Outer Plaster
Outer Plaster
Thu Feb 26, 2015Total posts : 2
Topic: Outer Plaster
Hi all,
I am making external walls 4 inch thick (half brick) on first floor of  a small clinic. It should be fully waterproof. need no seepage at all. Could you please guide.
1).  How to make outer plaster fully waterproof. I want to use best option of material. No matter if it is costly.
2). Extra protection for waterproofing by which Putty, which Paint, which Primer. all should be waterproof.
Fri Feb 27, 2015Post  #1
You can use normal plaster with charcoal coating on it.
Or you can use stone or tile work.
Or you can use normal plaster with Liquid silicon coating over it.
The last option is the best but costly.
Fri Feb 27, 2015Post  #2
Dear Purvi
        In my view do the plaster with coarse sand have ratio 1;3 and after priming coat do water proof paint i.e. Apex or acrilic paint.
2052
Tiles Vs Plaster on outer wall
Last answer on 4/14/2014 7:53:27 PM. by awdhesh. Forum started by awdhesh
1068
building 8" wall onthe slab will effecet the on the outer side
Last answer on 7/4/2020 2:02:31 AM. Forum started by Badhavath Rajeshwar
961
SIR,I have made new home and i am staying there for last two months. RCC ground
Last answer on 9/7/2018 1:08:09 AM. by S L Gupta (Civil Engg). Forum started by kajal dutta
2924
3530
Is it ok to have,as per vastu, curved outer walls for homes especially if it is
Last answer on 8/31/2011 8:43:43 PM. Forum started by Mathew George
3071
Steel
1247
I have outer width for my house as 25.5. Is that valid
Last answer on 10/25/2015 8:28:33 PM. by JAI PRAKASH. Forum started by Ramesh
2437
Gypsum Plaster Vs S/C Plaster
2780
Plaster work
4626
time for paint and wall putty
2203
7005
35210
2693
cement plastering
8879
3992
1417
where are use in 20mm plaster
Last answer on 10/22/2016 11:07:01 AM. by S L Gupta (Civil Engg). Forum started by Babasaheb Gite
27
Rain Seepage from outer wall
Last answer on 4/5/2011 9:16:46 PM. Forum started by Dr Akshay
3965
water proofing of water tank
2929
Plaster
2780
Plaster work
3047
Plastering
1925
2004
PPC and OPC cement
11298
1871
suggest for exterior
7005
9157
1877
OPC and PPC cement
2157
2012
coarse aggregate
1826
Nice
2437
2996
2735
putty work on walls
2236
2827
2033
Gypsum
Checklist for Cement Plaster
Specification of ‘Plastering’
How to clean plaster ceiling?
Plastering
Plastering
What type of finishing is recommended for POP?
The plaster should be finished to a true and plumb surface.The plaster should be finished to a proper degree of smooth..
