Home -> Forums -> Construction -> Foundation -> PERFECT STEEL HEIGHT,WIDTH & NO OF QUANTITY
Sat Jan 16, 2016Total posts : 3
DURJOU KUMAR MONDAL
DURJOU KUMAR MONDAL
Topic: PERFECT STEEL HEIGHT,WIDTH & NO OF QUANTITY
My Dear Gharexpert ,
Pl answer my 4 nos of question as per attached plan,where ground floor will be 28feet * 48feet & it would be increase 4feet all 4side as cantilever!!! Then after 1st floor to 3rd floor will be for[28+(4*2side)]36feet x55feet [48+(3.5*2side)]. so,36*55=1980sft will be rcc roof for each floor
there are my question is 1.how many clolumn required?
2.what will be the column width & beam width?
3.how many foot long would be column for g+3rd floor?
4.what will be the tmt bar of MM for every column,beam stair(3.75'*3.75')?
So please assist me as my attached & revert me with column,meam,stair & 4 no of 1980sft roof.
Attachments: PROJECT OF 1ST TO 3RD FLOOR.xlsx on Sat Jan 16, 2016,&n
Mon Jan 18, 2016Post  #1
Dear Mondal
        As we have earlier reply your query that you are constructing 4 story building and it is not hit and trial method to explain so responsible structural design with out any field data i.e. bearing capacity of soil and loading condition so better to contact any designer and it is economical to you after expanding small amount. If any one told you lay 24 column but your building design need 20 than there is wastage of 4 column same case with Steel bars.
Sat Jan 23, 2016Post  #2
I think you are wasting your time by asking the same questions again and again.
Mon Jan 25, 2016Post  #3
DURJOU KUMAR MONDAL
DURJOU KUMAR MONDAL
Post subject: Mr JoyPrakshjee
Dear Mr. Joyprakashjee,
Not at  all I am not westing my time actually.U have not given me the right answer of my question, You just told me that there would be 26 no column required but u not answered that how would be the structure of the column & beam,how would be the width of same.
Durjoy
3626
chair in slab steel
Last answer on 4/23/2014 8:34:50 PM. by shaik khaja nayab rasool. Forum started by shaik khaja nayab rasool
3278
1818
I want to change front design of my house
Last answer on 8/15/2020 12:59:30 PM. by tiyas. Forum started by Adnan Saifi
13756
3380
Square 4 side Pyramid Frame by MS Steel for RCC.
Last answer on 7/29/2014 2:33:14 PM. by S L Gupta (Civil Engg). Forum started by Shailendra Singh
2512
Last answer on 5/20/2010 8:45:36 AM. by Dhananjay. Forum started by shivprasad
2645
please send me some sample plot size of 18ft width and height 60ft. thanks.
Last answer on 8/14/2012 2:29:54 PM. by Gunjan Utraja. Forum started by gurmeet singh khaira
65240
1872
Bedroom Makeover
Last answer on 11/10/2014 7:28:56 PM. by JAI PRAKASH. Forum started by Kim waun
804
647
how to choose the perfect Forex broker?
Last answer on 1/18/2022 2:33:18 AM. Forum started by everap
2421
start construction Steel use
2999
2396
Last answer on 6/24/2013 9:59:46 PM. Forum started by chethan
2673
shuttering calucation
Last answer on 4/8/2014 1:21:34 PM. by S L Gupta (Civil Engg). Forum started by shaik khaja nayab rasool
2227
UNIT
Last answer on 7/3/2019 12:34:37 AM. by S L Gupta (Civil Engg). Forum started by sanjoy koley
20129
5178
RCC Lintel , cast and material esitmate
Last answer on 7/3/2020 10:47:13 PM. by S L Gupta (Civil Engg). Forum started by ndmalam
1763
2684
Pillar
2140
Curing urgent
2373
structure work
5166
Pillar foundation
2204
new house
2821
building a house
1992
Construction Agreement
3091
Foundation
2273
Foundation
1477
10048
3661
Foundation
2115
Structure proof checking
2558
Foundation design
2462
2469
Saria and cement
3657
Wall Thickness
2679
3180
13268
Steel Type
Type
KITCHEN
"KITCHEN"THE POWER HOUSE
SOUTH-EASTCORNER IS SUPPOSED TO BE THE PLACE OF LORD AGNI,GOD OF FIRE.
HSD
Precautions
