Home -> Forums -> Construction -> Finishing -> POP OR GYPSUM
POP OR GYPSUM
Tue Oct 25, 2016Total posts : 0
shreenivas
shreenivas
Topic: POP OR GYPSUM
which is btter to use
POP or GYPSUM
Finishing-Construction Questions (36)
2709
3049
False Ceiling--POP or Gypsum, which is better?
Last answer on 4/28/2015 8:41:23 PM. by JAI PRAKASH. Forum started by ajaywahi
2170
Last answer on 5/5/2014 12:08:29 PM. by S L Gupta (Civil Engg). Forum started by ajaywahi
3294
Last answer on 4/27/2010 9:56:03 PM. by raghuns1974. Forum started by Mohit
2991
5921
gypsum
Last answer on 1/14/2022 2:23:44 AM. by Antoni11. Forum started by shaju
2076
gypsum
Last answer on 2/6/2011 5:34:36 PM. Forum started by shaju
2519
l would like to see more gypsum designs
Last answer on 1/14/2022 3:20:41 AM. by S L Gupta (Civil Engg). Forum started by salome kapanga
2475
i see pop designs , there r 2 to 3 designs , how can i see some more pop designs
Last answer on 8/20/2010 1:50:35 PM. by Gunjan Utraja. Forum started by ravi
1750
1655
2930
i need to know more about how to design ceilings made out of gypsum material.
Last answer on 6/27/2021 4:32:10 AM. by Nisha Batra. Forum started by kagz ecma
2155
KINDLY TELL ME ABOUT DIMENTION OF FALL CEILING IN GYPSUM BORAD.
Last answer on 6/30/2012 11:31:21 AM. by Ar. Manoj Ralen. Forum started by Pawan Jain
2684
Kids room ceiling designs
2318
can you use brilliant white gloss paint on mouldings(pop)
Last answer on 1/20/2011 8:22:05 PM. by Dinesh Manaktala. Forum started by coby
2894
please i need an interior decoration cataloge showing all the pop desings in the
Last answer on 1/21/2011 11:13:26 PM. by Gunjan Utraja. Forum started by emmanuell
3065
PLZ SEND SOME POP DESINE FOR LIVING ROOM ,KITCHEN AND BED ROOM
Last answer on 7/3/2020 11:32:54 PM. by Swati Satija. Forum started by ASHOK CHAWLA
3187
i want to have some pop ceiling designs & ideas for my living & bedroom
Last answer on 1/23/2022 9:11:33 PM. by Swati Satija. Forum started by RAM
2331
2004
Last answer on 2/2/2022 11:26:31 PM. Forum started by manjunath
2577
Elevations Required
Last answer on 2/2/2022 10:53:23 PM. Forum started by gangula
3190
Cracks on the walls
Last answer on 1/14/2022 10:40:04 AM. by S L Gupta (Civil Engg). Forum started by devjani roy kashyap
2880
Wall painting
2070
CEMENT PANI - Plaster Works
1938
Triangle House roof
Last answer on 1/14/2022 4:58:49 AM. by S L Gupta (Civil Engg). Forum started by tayyab
3853
Last answer on 1/14/2022 4:09:54 AM. by S L Gupta (Civil Engg). Forum started by Sameer
2320
tiles or marble
Last answer on 12/4/2021 5:12:27 AM. by S L Gupta (Civil Engg). Forum started by aammiitt
3520
stone wall cladding
1506
help
10846
Lappam vs Wall Putty
1919
Last answer on 3/5/2016 9:18:00 PM. by JAI PRAKASH. Forum started by raj
1822
1947
1871
Final Handover
Last answer on 5/14/2014 2:15:33 PM. by S L Gupta (Civil Engg). Forum started by Ahmed
2107
2553
Thermal Insulation of Home
Last answer on 3/29/2010 7:23:40 AM. by abhijeet pawar. Forum started by akkulshrestha
Gypsum
Ceiling
Which are advantages and disadvantages of POP?
POP expands very slightly on setting.
What are the characteristics of POP?
Plaster of Paris is easy to spread and level.It is high fire resistant
Which tools are recommended for POP?
Finishing trowel: It is used for spreading and leveling plaster on the surface.
What type of finishing is recommended for POP?
The plaster should be finished to a true and plumb surface.The plaster should be finished to a proper degree of smooth..
