Home -> Forums -> Construction -> Foundation -> PROCEDURE FOR MEASURE PLINTH HEIGHT
Wed Nov 17, 2010Total posts : 4
SUNIL
SUNIL
Topic: PROCEDURE FOR MEASURE PLINTH HEIGHT
MY BUILDER MEASURING THE PLINTH HEIGHT FROM GROUND LEVEL WHERE AS I AM ASKING HIM TO MEASURE IT FROM BOTTOM OF GROUND BEAM . WHAT IS THE CORRECT METHOD
Thu Nov 18, 2010Post  #1
The quarry is not clear, for what purpose to measure the plinth height, write in detail. However the floor level of the building or house is called plinth level.
Fri Nov 19, 2010Post  #2
MANOJ UPADHYAY
MANOJ UPADHYAY
Post subject: PROCEDURE FOR MEASURE PLINTH HEIGHT
Plinth height should be measured from top of the road in front of building.
Sat Nov 20, 2010Post  #3
SUNIL
SUNIL
WE HAVE DECIDED TO MAKE PLINTH LEVEL OF 3 AND HALF FEET HIGH. NOW THERE IS A DIFFERENCE OF ABOUT 9 INCHES IN GROUND LEVEL AND  BOTTOM OF  GROUND BEAM AS GROUND BEAM IS LAID ON RAISING THE COLUMNS 6 INCHES ABOBE GROUND .I WANT THAT PLINTH SHOULD BE MEASUREED FROM BOTTOM OF GROUND BEAM WHERE AS BUILDER WANTS TO MEASURE IT FROM GROUND LEVEL
Sat Nov 20, 2010Post  #4
Dear sunil
        In my opinion the height should be taken from the natural ground. If you laid the ground beam 1' or more than the 6'' you laid than what will be the position.
4911
How much it cost for laying a foundation for a 30x40 site upto 7ft deep and plin
Last answer on 5/4/2013 2:20:44 PM. by nithun. Forum started by nithun
2099
increase the height of plinth area
Last answer on 5/3/2013 11:36:10 AM. by S L Gupta (Civil Engg). Forum started by randhir
2669
procedure of building layout detail
Last answer on 3/15/2011 6:11:55 PM. by Mohini Sharma. Forum started by kanwer sajjad
3083
What are the basic things that are needed while painting?
Last answer on 10/8/2010 11:47:06 AM. by Sazid Ali. Forum started by Sazid Ali
2769
2343
Pls what are the procedures in doing this floor
Last answer on 5/23/2012 12:44:44 PM. by S L Gupta (Civil Engg). Forum started by lilian
2873
Column Size and distance
6548
3465
Last answer on 2/4/2022 11:19:50 PM. by Vaasku. Forum started by jayakrishnan
3632
show plinth design of small beautiful home approxematly 1500sft
Last answer on 6/14/2012 10:55:58 PM. by Gunjan Utraja. Forum started by manzoordar
3004
roof height
Last answer on 4/15/2021 2:13:51 PM. by majomathew. Forum started by majomathew
4271
1844
my flat is on 3rd floor and is SW facingpl advise necessary corrective measures.
Last answer on 12/12/2011 7:39:57 AM. Forum started by poornima
2651
where to keep pooja mandir in living room measuring 17X19sq feet with terrace in
Last answer on 3/24/2012 2:53:23 PM. Forum started by srpatil
I have a plot measuring 34 sqft in East
Last answer on 6/22/2012 9:35:07 PM. by Amit Hasija. Forum started by BIDYADHAR SAHOO
2497
Hi Want to know that in false ceiling how do cove is measured for billing
Last answer on 7/16/2021 7:21:25 AM. by S L Gupta (Civil Engg). Forum started by Sandeep
5817
Industrial shed construction
Last answer on 1/8/2022 4:18:30 AM. by S L Gupta (Civil Engg). Forum started by shikha Chetal
2641
Structural Design
Last answer on 1/15/2022 3:01:21 AM. by Anthony Lofu. Forum started by ajay
Dear Sir iam sr.civil engineer with adequate experience.so please tell me the pr
Last answer on 1/16/2021 1:07:32 AM. Forum started by SANJAY DUSANE
2691
Pillar
2145
Curing urgent
2386
structure work
5171
Pillar foundation
2214
new house
2826
building a house
1996
Construction Agreement
3098
Foundation
2279
Foundation
1482
10062
3669
Foundation
2124
Structure proof checking
2570
Foundation design
2473
Saria and cement
3661
Wall Thickness
2687
3197
13275
Steel Type
Cupola installation tips
Tips for cupola installation
Preventive
Fountain Types
Protect
