Home -> Forums -> Construction -> Paints More -> Painting old house
Painting old house
Thu Jan 13, 2011Total posts : 2
soumyabrata
soumyabrata
Topic: Painting old house
I have to paint an old house. The house was painted many years ago.
Please guide me how to paint it properly.
Thu Jan 13, 2011Post  #1
Hitesh.kumar22
Hitesh.kumar22
Post subject: Some tips for painting an old house.
Hi Soumya,
To paint an old house, you should clean and smooth the surface before painting is done. Also remember to rectify the existing surface problems like dampness and cracks. Make the joints and cracks smooth with plaster. After that it depends upon the techniques of application with brushes, roller or spray machines.
For more details you should take help from the website www.Gharexpert.com from their paint section or follow the link given below.
http://www.gharexpert.com/tag/Paint/Paint.aspx
Tue Jan 24, 2017Post  #2
The preparation of a surface is 90 percent of painting job. Even the highest quality paint won’t adhere properly if the underlying surface is not prepared properly. Good surface preparation means clean and smooth surface.
Tips for Surface Preparation
  •  Rectify existing surface problems such as dampness, cracks etc. before actual painting process.
  • Check for hand prints, greasy fingerprints, algae as well as dirt and stained marks.
  • Use a scraper, putty knife or scrub brush to remove any dirt, grease, rust, or flaking.
  • Fill in the holes, cracks and joints with plaster.
  • Clean and dry the surface.
  • Make sure the area to be painted is well ventilated as well as free of dust.
  • As far as possible, don’t paint under much humid conditions.
Do before starting painting work
  • Remove materials such as light fixtures, curtains and their rods etc. from the room to protect them paint splashes. The materials which cannot be removed out should be placed at the center and be covered with a canvas or plastic sheet.
  • Place a large bin with a plastic bag to gather debris or paint splashes. A dirty work place is not only unsafe but can slow the process of painting also. Also make use of canvas to cover the floor to avoid paint splashes.
  • Insert nails and hooks for pictures. Fill the holes made by nails with plaster and sand before painting again.
  • Use painter’s tape to cover up the area that you do not want to paint. Also do the same for doors, windows and ceilings that you can not remove.
This is how your room will look alike after base coat or first coat of Primer
  • Make use of protective measures such as leather gloves, respirator all the time while doing scrap.
  • Sand the wood lightly in case of new woodwork for new paint.
  • Use a solution of washing soda to clean walls so that the walls can easily accept the paint.
  • Damp sponge into the solution and apply on the ceiling first and then on the walls from bottom to top.
  • Strip layers of paint using a chemical stripper or a heat gun to remove old layers of paint on wood work. Keep a distance of one foot while using heat gun and remove the paint as it flakes.
End result of so much hard work and these tips may be this...
  • Check all masonry surfaces, voids, pores and cracks are filled with filler. Make sure the wood surface is free from all loose dust. Smoothly rub it with Emery paper).
  • Check all nail holes, cracks and other defects in wood surfaces are properly filled and smoothed.
  • Apply sandpaper or wire brush to remove rust, grease, oil  and loose mater etc. on steel surfaces. The surface should be dry and free from moisture.
  • Check the use of primer on painting of new surfaces.
  • Ensure adherence and reliability of old paint in repainting works.
  • Verify quality and make of the paint.
  • Confirm uniformity of thickness for application of each coat of paint.
  •  Observe painted surface for paint drops, brush marks, waves and for variation in color, texture and finish.
  • Check the places that are difficult to reach such as edges, corners, gaps, cracks. Ensure the joints, bolts and nuts are properly painted.
  •  Check the paint which falls on floors and walls etc. is completely cleaned and glass panes are clean.
Paints More-Construction Questions (26)
3470
paint
2309
New Home
4647
4905
Last answer on 12/31/2020 2:16:17 AM. by Vinika. Forum started by VMUTHAIYAN
4041
Paint vs Wallpaper
2544
need paint in my house so wants to see a demo of drawing room how it look after
Last answer on 7/3/2020 10:09:31 PM. Forum started by muddassir
1798
Last answer on 8/29/2016 12:10:36 PM. by S L Gupta (Civil Engg). Forum started by vishal
6818
Kitchen Ventilation
Last answer on 1/19/2022 2:55:03 AM. by sugantha. Forum started by sukamalroy
3228
I want to paint my house plz suggest the colour for internal rooms & external
Last answer on 2/15/2012 10:39:54 PM. by skycrane. Forum started by vago suzare
1663
Is the combination of Grey Color for House painting good as per vaastu
Last answer on 8/31/2021 1:54:40 PM. by S L Gupta (Civil Engg). Forum started by Priyanka
2294
Washable Paints good or bad
Last answer on 11/20/2011 11:49:18 AM. by Amit Hasija. Forum started by raghuam
2434
exterior painting
Last answer on 3/24/2014 9:24:11 PM. by vamsi. Forum started by Muralidharan
2924
3317
Last answer on 5/1/2012 11:09:41 AM. by S L Gupta (Civil Engg). Forum started by pankaj sharma
2792
Sir,I am plaing to constuct my house in the old city Amritsar .The size of the p
Last answer on 12/26/2011 7:49:20 PM. by shefali. Forum started by jasbir
2691
2815
how much will a flat sell without approval if its like 17 years old with 850sqft
Last answer on 3/6/2018 4:03:32 AM. by anandrao. Forum started by anandrao
3436
sunmica
Last answer on 12/6/2012 10:52:25 PM. by shailesh kumar singh. Forum started by tanaji
8880
2412
Very useful Website for all the Professionals whoever involved in Construction F
Last answer on 12/31/2020 2:29:49 AM. by Gunjan Utraja. Forum started by suresh
1825
wall primer
Last answer on 1/10/2016 9:04:01 PM. by JAI PRAKASH. Forum started by Anu
1892
Wall Putty
Last answer on 3/11/2014 2:11:56 PM. by Abhishek Garg (Builder & Engineer). Forum started by Purvi Panchal
2188
Exterior wall putty
Last answer on 1/17/2014 11:53:01 AM. by S L Gupta (Civil Engg). Forum started by Purvi Panchal
2087
WHAT IS THE COSTING OF VNYLE FLOORING PER SQ FEET.
Last answer on 7/27/2012 1:05:42 PM. by S L Gupta (Civil Engg). Forum started by mksharma
1780
Place to buy cheap paints
Last answer on 10/29/2011 6:35:31 AM. Forum started by judyparker
How to Paint Old Furniture
Painting
Environmentally
Environment
Environment Friendly Houses
