Home -> Forums -> Construction -> Cement Concrete Flooring -> Per Sq:ft rate for flooring
Sat Jul 21, 2012Total posts : 1
sam_m400
sam_m400
Topic: Per Sq:ft rate for flooring
Sir
What is appropriate rate for cement Concrete Flooring?
I am planning to put the mortar( Cement+Sand + aggregate (40mm) ,then above it laying the tiles. i know tile laying is separate rate, but i need to calculate the approximate rate per Sq:ft including material + labour  till concrete flooring as i received 12 Rs per Sq;for tile flooring only labour
What is mortar mixture we should use for cement flooring?
What is proportion of mortar mixture/any precaution  needed for compound passage flooring?
Sam
Mon Jul 23, 2012Post  #1
Dear sam
There are three steps
1. To lay basecoat i.e.lay 3'' to 4'' thick cement concrete Ratio 1;8;16 with brick / stoen 40 mm gauge.Then lay 12mm to 20 mm cement coarse sand mortar Ratio 1;3 and finally on this mortar lay tile of flooring. for more about tile flooring see the link below
http://www.gharexpert.com/articles/Tile-Flooring-1524/Tile-Flooring,-designs--installation-guidelines_0.aspx
Cement Concrete Flooring-Construction Questions (27)
5664
What is the cost of the emulsion paint per sq ft as per today's market rate?
Last answer on 2/14/2013 11:17:01 AM. by Jemimmarichardson. Forum started by Rani
3476
labour charges rates
4735
CONSTRUCTION COST OF 3 STOREY BLDG
Last answer on 7/4/2020 2:47:14 AM. by kavi77. Forum started by shakirk78
Estimation for ground + 2 floor
Last answer on 2/27/2015 10:52:31 PM. Forum started by sboloor
Current construction cost for Marble and Vitrified flooring
Last answer on 12/4/2009 2:54:24 PM. by narendra barde. Forum started by rajendra
3196
labour cost
5684
Having a plot of 30'X40' south facing, want to know floor plan up to 700 sq ft w
Last answer on 2/16/2019 2:25:41 AM. by Amit Hasija. Forum started by viairsung
3130
1778
Last answer on 8/8/2016 2:46:05 PM. by S L Gupta (Civil Engg). Forum started by arvindkori
2176
18383
3925
2185
Marble required for flooring
Last answer on 1/7/2022 12:44:11 AM. by S L Gupta (Civil Engg). Forum started by K. Basu
5354
main door vastu question
Last answer on 7/4/2020 3:03:42 AM. by geetika. Forum started by sujatha
2737
Contractor Quotation Problem
Last answer on 6/27/2014 2:43:20 PM. by Atul D.. Forum started by Atul D.
14313
20 sq ft and 50 sq ft how can i make house with vastu
Last answer on 12/24/2012 3:50:59 PM. by S L Gupta (Civil Engg). Forum started by saravanan
2166
helloI wanted to know how much should I be charging for a client who just wants
Last answer on 8/9/2013 10:02:39 PM. by Purvi Panchal. Forum started by sruti
2328
Roof flooring
1393
1399
Colored concrete floor
Last answer on 10/22/2016 11:14:47 AM. by S L Gupta (Civil Engg). Forum started by Pooja
1522
concrete floors
1989
1642
floor construction
2122
Floor thickness
2465
Material and cost of Tezzarro flooring
Last answer on 7/20/2012 11:33:53 AM. by S L Gupta (Civil Engg). Forum started by Raj
What is acre
Through
Terrazzo
Drawing
Drawing Room Flooring
