Home -> Forums -> Construction -> Pillar Work -> Pillar and beam size for my house plan
Thu May 25, 2017Total posts : 2
shakthi
shakthi
Topic: Pillar and beam size for my house plan
sir,
i am planning to construct a house ground floor and 1st floor. please find the plan in attachment.
17'x20' is the inside size of the ground floor. i want to know how many pillar required.
do i need to run the beam in the middle ? (see green colour lines for beam)
please give me your suggestion.
Attachments: check 1.JPG on Thu May 25, 2017,&n
Thu May 25, 2017Post  #1
       Your attached drawing is not clear. Place 9 columns and lay the beam.
Thu May 25, 2017Post  #2
shakthi
shakthi
Post subject: Gupta sir,
thanks for your reply,
please check the attached PDF. i have placed 9 columns, is it what you have suggested?
if so, i cannot actually put a column in the middle.
Attachments: 123ef.pdf Thu May 25, 2017,&n
4431
1528
Guide me
65239
3129
Plinth beam at ground level
2694
2823
4389
Last answer on 11/15/2016 1:51:43 AM. Forum started by K Srinivasan
4039
1846
3770
small size plot, pillar location, size and number of required pillars, floor plan
Last answer on 3/20/2014 2:49:26 PM. Forum started by basbrem
How many Pillars + Beams need for 30x40 ft land
Last answer on 11/11/2014 12:01:40 PM. Forum started by DK
3837
Roof Beam
2525
3925
Distance between pillars
Last answer on 1/16/2014 3:37:45 PM. by Ahmed. Forum started by Badohi Singh
2783
3792
3303
1796
Sir, my plot is west and south facing with Total size of size of 31x38 Ft, pl
Last answer on 4/25/2021 6:53:14 PM. by S L Gupta (Civil Engg). Forum started by Swatej Kumar
32560
Cost of RCC Pillar
6437
position of pillars
1878
column
1780
First floor plan suggestions
2524
Pillar cost
42125
12462
First floor construction
2501
2503
Length of cantilever beam
2537
RCC column (pillar)
9228
pillar size in distacce
9195
2823
2694
1993
2208
3161
Laping length requirement
Brick Pillar
Centering
