Home -> Forums -> Construction -> Foundation -> Pillar distance and steel rod dia
Fri Aug 01, 2014Total posts : 0
SAROJINI
SAROJINI
Topic: Pillar distance and steel rod dia
hi,
We have a duplex that is constructed on SSM. Now we want to add pillars and extend the FF and add SF. Plot size is 40 x 40 , slant at the back end. Now the pillars are going to be on the compound wall and floors on cantilever.Is 3 pillars (18ft apart) sufficient on each side for 3 sides and 4th side SSM. what should be the rods size for each pillar?
65239
2823
2163
R.C.C 1:2:4
Last answer on 3/18/2014 1:14:13 PM. by S L Gupta (Civil Engg). Forum started by ijazulhaq
42125
3608
9228
pillar size in distacce
722
1979
Last answer on 10/13/2016 11:06:46 AM. by S L Gupta (Civil Engg). Forum started by Saneto Fernandes
3792
13772
overlap length to steel
2501
2101
2694
12462
First floor construction
1480
Construction of house with basement.
Last answer on 5/10/2016 11:38:09 AM. by S L Gupta (Civil Engg). Forum started by MUSHAHID RAZA
6549
2652
Structure drawing - Is it OK ?
Last answer on 6/4/2011 4:42:55 PM. by P. Panchal. Forum started by manjuks
2554
Need support regarding Beam steel design
Last answer on 1/7/2014 2:57:59 PM. by S L Gupta (Civil Engg). Forum started by Sunil Kumar
2255
Sreel pillars(post)
2684
Pillar
2140
Curing urgent
2372
structure work
5166
Pillar foundation
2203
new house
2821
building a house
1991
Construction Agreement
3089
Foundation
2272
Foundation
1476
10048
3660
Foundation
2115
Structure proof checking
2558
Foundation design
2459
2467
Saria and cement
3656
Wall Thickness
2678
3179
13267
Steel Type
Brick Pillar
Type
HSD
Precautions
Steel
Steel Roofing
TMT
