Home -> Forums -> Construction -> Foundation -> Pillar & plinth beam frame work avoiding stone foundation
Tue Aug 19, 2014Total posts : 8
tp_bangalore
tp_bangalore
Topic: Pillar & plinth beam frame work avoiding stone foundation
Hello Sir,
I am not a Civil Engineer and i have no experience in construction field at all. So please excuse my poor way of asking the question. I am constructing house in bangalore with help of my friend who is the engineer.
Want to know why this method of construction is better?
I was told by my engineer that there is no need of stone foundation instead he said that he will raise pillar(columns) from foundation level and do a plinth beam frame work on the ground level. I am building a 3 storey house which consist of Stilt floor and duplex on the top.
But my understanding was when they raise the pillars they link the pillars with stone foundation. Once it is done they do the plinth beam framework on the gound level. When i asked this question to my engineer he said this method better.
I have attached the picture.
Thanks,
Tej Patil
Attachments: 303.JPG on Tue Aug 19, 2014,&n
Tue Aug 19, 2014Post  #1
             In the frame work building, raise the columns/ pillars up to ground level and joint all the pillars with plinth beam, also lay beam for walls to be constructed at ground if any according to plan. In the beam where we want to construct the wall additional reinforcement will be laid.
Wed Aug 20, 2014Post  #2
tp_bangalore
tp_bangalore
Hello Gupta Sir,
Thank you for your response. I want to know is this safe because usually in building foundation they link pillars at foundation level i mean below the ground. But here my engineer is not linking the pillars below the ground instead he is constructing the plinth beam frame work at the ground level. I just want to know why this is ? Is it safe during earthqaukes, also does this bear the weight of the duplex on the first floor ?
Thank You,
Tej
Wed Aug 20, 2014Post  #3
           The safety against earth quake for laying beam at plinth level is o. k.As you want safety for duplex, the weight is to be bear by columns/ pillars.not by plinth beam.
Fri Aug 22, 2014Post  #4
tp_bangalore
tp_bangalore
Thank You Gupta Sir.
Thu Aug 28, 2014Post  #5
tp_bangalore
tp_bangalore
Dear Gupta Sir,
I have one more question regarding this. Please excuse me if I am repeating the question.
Since my foundation does not have Stone Foundation and I have only columns/pillars and plinth beam at ground level. Since i am construction G + 3 levels. I this a safe and strong construction or do I need Stone foundation. I am just worried.
Could you please let me know.
Thanks,
Tej Patil
Mon Sep 01, 2014Post  #6
       The load is to be bear by RCC column / pillars no by walls.
Wed May 10, 2017Post  #7
rajeev
rajeev
Post subject: piller on above plinth beam
sir
initially i lay down foundation on stone and three layer on bricks and and make plinth beam on above thses bricks , there is no Rcc cloum intitally but i want change my plan.. can thre is way to construct RCC beam above plinth beam
Thu May 11, 2017Post  #8
Dear Rajeev,
       In my opinion there is no use to lay RCC Beam on brick work as ultimately load is bear by the foundation below it.
9196
3883
stone foundation
14599
1846
3129
Plinth beam at ground level
5691
2279
Plumbing works
Cost of Foundation
Last answer on 9/11/2012 1:51:22 PM. Forum started by RENJI
4431
4665
Regarding Beam
3397
Bathroom Cleaning Tips
6529
3459
What is gap to maintain in Plinth/beam/Pillar/roof/Chejja
Last answer on 11/10/2016 5:26:49 PM. by S L Gupta (Civil Engg). Forum started by sam_m400
3657
3651
2108
foundation
Last answer on 7/3/2020 11:10:18 PM. by S L Gupta (Civil Engg). Forum started by nazeersyed
4039
3262
compound wall
1701
material requirememt question
Last answer on 12/26/2015 7:41:53 PM. by JAI PRAKASH. Forum started by sushantsah
2684
Pillar
2140
Curing urgent
2372
structure work
5166
Pillar foundation
2203
new house
2821
building a house
1991
Construction Agreement
3090
Foundation
2272
Foundation
1476
10048
3660
Foundation
2115
Structure proof checking
2558
Foundation design
2467
Saria and cement
3656
Wall Thickness
2678
3179
13267
Steel Type
Brick Pillar
Designing
Designing a Foundation
Protect
Protect Your Family from Dust
Appropriate
Colors
Colors of Kota Stone
Kota Stone is a natural stone found in attractive, beautiful and eye soothing natural shades of greenish blue and brow..
