Home -> Forums -> Construction -> Plumbing -> Piping material for in doors pertaining to hot water service
Sat Mar 19, 2011Total posts : 2
amdidgur
amdidgur
Topic: Piping material for in doors pertaining to hot water service
Good morning Gents,
We have recently constructed a home and have facilities for geysers in each bath room. Now I wish to use those facilities for the solar water heating systems. What will be best option and the materials of construction for the piping system for in doors and out side?
Thanks in advance
Tue Mar 22, 2011Post  #1
Dear sir
       For hot water use G. I. pipes for piping system for indoor and out door of the house.
Wed Mar 23, 2011Post  #2
Ar. Suresh Kothari
 Ar. Suresh Kothari
Post subject: Piping material for in doors pertaining to hot w...
I think C-PVC pipe is best solution for hot water piping for indoor. The Hot water
damage the G.I pipe hence need to replace after few years, while C-PVC with alumium lining in between will last longer time,hence may not need to replace it. It is better to use outside also with POP coating
Ar. Suresh Kothari
Plumbing -Construction Questions (39)
2230
sewage pipes
9174
Related to Sunken Slab
1539
Dear sir,our bore well water available with 1650 ppm salt content.please suggest
Last answer on 5/9/2016 11:04:57 AM. by S L Gupta (Civil Engg). Forum started by ananth
1752
Dear Sir Constructing 72x43 East facing house.Pl guide me for water supply pipe
Last answer on 9/30/2015 8:59:54 PM. by JAI PRAKASH. Forum started by Sudhir Pathak
3804
cpvc pipes v,s gi pipes
2388
7232
2 lakh litre water tank
2054
Pine wood
Last answer on 1/27/2015 7:34:42 PM. by JAI PRAKASH. Forum started by paresh
3228
how to find a hot girl on the internet?
Last answer on 7/31/2022 12:31:53 PM. Forum started by Rinder76
5492
Redheads are so hot
Last answer on 1/20/2022 10:42:47 PM. Forum started by John
1755
2625
How to hide Rain water pipe
3114
Hot Water Tank
1008
I want to hire services for estimating material quantities during various stages
Last answer on 9/26/2018 12:22:00 AM. by S L Gupta (Civil Engg). Forum started by Vinay
1989
PLUMBING
2931
2100
2220
DOOR & WINDOW FRAMES
Last answer on 6/7/2015 1:21:11 AM. by JAI PRAKASH. Forum started by Snehal Shah
6271
Water Tank Quality
3114
Hot Water Tank
2915
Sand in Water
3380
Diverters for Bathroom
2562
2145
40516
2083
GI pipe Vs CPVC pipeline
2931
1755
2080
Toilets
1988
Wall mounted cummod vs normal
5055
2775
2388
1855
3076
Swimming pool
2541
water softner
2682
commode type and flush type
4193
to shut off water to house
General
Relax
Relax yourself with Jacuzzi Bath
Relax or rehydrate your body with Jacuzzi bath. Jacuzzi bath is amazing stress reliever and best luxury experience to ..
Which are various brands of pipes for drainage of soil water?
Brands of pipes for drainage of soil water-C.I. Pipes-CIC..........
Checklist for Plumbing
