Home -> Forums -> Construction -> Start Construction -> Planning to Build a new house
Mon Aug 11, 2014Total posts : 1
sree
sree
Topic: Planning to Build a new house
Hi Team, Greetings !
This website gives a very good insite for the Construction and I would like to thank you.
I am planning to build a Duplex house(Ground +1) near Electronic city Bangalore(off hosur road).
My plot is 60*50 and South facing and I am planning to build a new house as per Vasthu. So can you please provide with all the relevant plans /advices required for a built area of 1500sq ft in the ground and 1500 sq ft  duplex first floor = total 3000 sq ft. Looking for 5 BHK house with attached bath for 4 rooms, pooja, kitchen and living.
Sree
Thu Aug 14, 2014Post  #1
After
completion
of the architectural plans, we will recommend and send to you a few pictures/3-D models of the homes. In those pictures, we will ask you to shortlist the items of the exterior elevations. You can also send us the pictures of homes that you like. Through the existing pictures, it will be easier for you to shortlist the material and shape of exterior elevation.
6127
1761
sir.iam in tamilnadu.we started to plan build new house in 900 sq.ft.i need some
Last answer on 7/27/2016 2:34:54 PM. by Beenu Phogat. Forum started by madhu
2429
3488
2301
New Home
3614
1713
our house is 1300sqft say the plan how it can be built
Last answer on 7/12/2009 2:37:32 PM. by Priti Arora. Forum started by sonali
4249
860sqft construction
Last answer on 10/12/2015 6:35:12 PM. by Rahul. Forum started by Shivaprasad
2095
Last answer on 11/21/2015 12:12:42 PM. by SACHIN. Forum started by SACHIN
1206
Sir i m planning for new house .. which wooden frame is best sal or teak or deod
Last answer on 8/16/2018 2:03:02 AM. by S L Gupta (Civil Engg). Forum started by Shivam gupta
5944
new construction in 300 sq yards place ...planning
Last answer on 2/20/2011 12:22:40 PM. by Gunjan Utraja. Forum started by vihal madishetty
can start a new building in adi month ?
Last answer on 10/5/2021 8:35:49 AM. Forum started by senthilvel
8150
Last answer on 7/3/2020 9:42:30 PM. by Beenu Phogat. Forum started by Prabhakar
1708
i want cost estimAtion for 800sq.ft house plan.
Last answer on 7/28/2016 3:17:15 PM. by S L Gupta (Civil Engg). Forum started by ram
4370
828
I want to a resident house plans east facing East to west 24feet and south to No
Last answer on 8/13/2020 4:15:16 AM. Forum started by Manash Prusty
2312
hi im new home plan frent 36 light 25
Last answer on 7/3/2020 10:19:19 PM. by S L Gupta (Civil Engg). Forum started by sandeep
1712
Last answer on 7/28/2016 3:16:51 PM. by S L Gupta (Civil Engg). Forum started by ram
1561
Individual House Construction
Last answer on 3/18/2016 3:31:59 PM. by S L Gupta (Civil Engg). Forum started by Nitin Khairnar
2442
3265
3278
4424
3970
2187
2695
4205
5159
2370
2289
1991
2441
2110
3190
2041
12508
2157
2005
2721
Orientation
Orientation of Building
How to Design a Garage
Happy
Happy New Year 2009
Environmentally
Environment
Environment Friendly Houses
