Home -> Forums -> Construction -> Start Construction -> Planning to construct G+5 Storey building
Wed Oct 30, 2013Total posts : 1
Naseer
Naseer
Topic: Planning to construct G+5 Storey building
Planning to construct G+5 storey  on 360Sq Yards.
Kindly contact me with the designs & elevations.
Please find attach layout
Attachments: Plot Layout.JPG on Wed Oct 30, 2013,&n
Fri Nov 22, 2013Post  #1
Dear Mr.Naseer
2255
Sreel pillars(post)
804
2006
6441
Column placement for house
4651
1652
1727
Want to construct commercial building in 3200sqft land.
Last answer on 10/8/2013 3:46:26 PM. by S L Gupta (Civil Engg). Forum started by sudheer
1644
planning to construct a single storey house very close to the sea
Last answer on 6/16/2014 11:07:07 AM. by S L Gupta (Civil Engg). Forum started by nkumar
3879
Reg planning & construction of 5 storey building in 50x60 site in bangalore
Last answer on 7/19/2011 3:32:31 PM. by palas. Forum started by Harsha
3368
2165
want to built double storey in foundation of 2ft.abv. gnd.level,is it possible?
Last answer on 10/19/2012 12:02:07 PM. by S L Gupta (Civil Engg). Forum started by ashish
2253
3795
Fire Stair case
3083
1702
Require Layout suggestions for a learning Inst. On 37'*49' plot
Last answer on 4/29/2016 11:06:07 AM. by S L Gupta (Civil Engg). Forum started by Sandeep
3502
1719
Need Valuate the building
Last answer on 9/4/2015 12:11:07 PM. by S L Gupta (Civil Engg). Forum started by Hanumantha
6147
3312
2312
2061
How to Design a Garage
Orientation
Orientation of Building
