Home -> Forums -> Construction -> POP -> Plaster of Paris
Plaster of Paris
Mon Jan 16, 2017Total posts : 1
Karan
Karan
Topic: Plaster of Paris
Can somebody give a step by step instructions on how to prepare and apply POP for wall/ceilings with specific details like water to POP ratio, time for drying, number of coats along with their plaster thickness, tools to use etc
Wed Jan 18, 2017Post  #1
Dear Karan,
          Application of plaster of Paris is following.
  • SCAFFOLDING
  • GAUGES(MEASURE)
  • FINISHING
  • CURING
  1. Scaffolding: The supports of the scaffolding should be sound and strong. It should be tied together with horizontal pieces.
  2. Gauges (Measure): To prepare a true surface and even thickness, plaster about 15 X 15 cm should be applied. Then the mortar should be laid on the wall between the gauges with trowel. The surface should be finished with trowel or wooden float. Excessive troweling should be avoided. All corners, edges, angles and junctions should be truly vertical and horizontal. Patches should not be on any portion of the surface.
  3. Finish: The plaster should give a smooth finish. All horizontal lines should be tested with a level. All jambs and corners should be tested with a plumb bob.
  4. Curing: Curing should be started after 24 hours of finishing the plaster. Plaster should be kept wet for a period of 7 days.
POP-Construction Questions (37)
3288
what material is used in ceiling other than plaster of paris?
Last answer on 6/1/2011 11:32:44 AM. by P. Panchal. Forum started by GURJEET
2713
Kids room ceiling designs
2212
Painting interior walls
3993
I am bout to put false ceiling in my entire flat. Please tell me whether I shoul
Last answer on 12/31/2020 2:46:11 AM. by mannu. Forum started by Anjan Biswas
2636
POP or Gipsum in false ceiling
Last answer on 6/20/2021 3:17:51 AM. by Ahmed. Forum started by kumar.x123
2029
we are master in this pop division,for any kind of plaster of paris design for i
Last answer on 5/26/2012 1:19:08 AM. Forum started by altaf
2626
please send me photo of various ceiling design by plasterof paris
Last answer on 7/2/2021 3:45:57 AM. by Ar. Manoj Ralen. Forum started by BIJIT
2924
4626
time for paint and wall putty
2780
Plaster work
2436
Gypsum Plaster Vs S/C Plaster
8879
3992
1417
where are use in 20mm plaster
Last answer on 10/22/2016 11:07:01 AM. by S L Gupta (Civil Engg). Forum started by Babasaheb Gite
7004
35210
2203
2693
cement plastering
1757
Cost of RCC ceiling plaster repair due to spalling
Last answer on 10/6/2014 12:46:05 PM. by S L Gupta (Civil Engg). Forum started by LM
3202
i want to have some pop ceiling designs & ideas for my living & bedroom
Last answer on 1/23/2022 9:11:33 PM. by Swati Satija. Forum started by RAM
2607
this pop desing is ok . i need more new design.
Last answer on 1/13/2022 10:58:57 PM. Forum started by manish.panchal
2710
could you send me some more good designs not satisfied with this type of pop cei
Last answer on 6/23/2021 6:18:33 AM. by Richa Shangvi Interior decorator. Forum started by maya
2167
30front 40 lambai south facing
Last answer on 6/21/2021 6:36:21 AM. Forum started by rahish
3404
show me more designs immediately
Last answer on 12/31/2020 2:22:34 AM. by Priti Arora. Forum started by vivek
2212
1408
crack on wall plaster by gypsum
Last answer on 11/22/2016 1:25:44 PM. by S L Gupta (Civil Engg). Forum started by Rizwan
1656
POP for wall finshing
Last answer on 11/26/2015 8:18:03 PM. by JAI PRAKASH. Forum started by Anu
1822
Last answer on 11/26/2015 8:17:28 PM. by JAI PRAKASH. Forum started by Anu
2437
Need Help internal walls cracking horizontally, diagonally and vertically
Last answer on 7/14/2014 2:25:04 PM. by S L Gupta (Civil Engg). Forum started by Srinivas
2281
POP work in my house, please share approx cost
Last answer on 4/15/2013 11:07:20 AM. by S L Gupta (Civil Engg). Forum started by sumitmalaviya
1780
Enter detail of discussion regarding this picture i m p o p man, i have meaning
Last answer on 10/7/2011 12:59:33 AM. Forum started by Johnson
1848
how can we sraw this design. please send me the steps of construction of this ce
Last answer on 6/27/2011 4:50:05 PM. by subhakankhi. Forum started by sachin
2353
POP on lime painted wall
Last answer on 2/7/2011 10:16:28 AM. by Nikita. Forum started by soumyabrata
2632
I AM LOOKING FOR A POP DESIGN THAT IS CONTEMPORARY.aNY BODY HAVE SOME IDEA?
Last answer on 1/28/2011 11:57:34 PM. by Nikita. Forum started by mi
2264
This picture remains incomplete without Lord Ganesha. Please do the needful. Tha
Last answer on 10/16/2010 1:55:13 PM. Forum started by ANIL TODI
3384
Can some one design this on ceiling?
Last answer on 8/16/2010 2:30:00 AM. by sukamalroy. Forum started by malay t
5133
False ceiling design
Last answer on 7/24/2010 3:45:46 AM. by krish. Forum started by Harish
Which are advantages and disadvantages of POP?
POP expands very slightly on setting.
Gypsum
Ceiling
Ceiling designs
Checklist for Cement Plaster
Specification of ‘Plastering’
How to clean plaster ceiling?
Plastering
Plastering
