Home -> Forums -> Construction -> Cement Plastering -> Plaster work
Plaster work
Fri Feb 17, 2017Total posts : 3
Alok Das
Alok Das
Topic: Plaster work
What is the best time for plaster work.how many days should rest before plaster of completing of bricks works.
Sat Feb 18, 2017Post  #1
Dear Das,
  • Plan the plastering when the surface receiving plaster coat is sufficiently matured.
  • Ensure that subsequent building operations do not cause any damage in plaster work.
  • Start external plastering from the top most floors and proceed downwards.
  • Start internal plastering after the structural work is complete.
  • Do plastering on ceiling wherever required before the walls are plastered.
  • Plastering is done with cement mortar or lime surkhi mortar on the irregular or coarse textured wall, column and ceiling surface to provide a smooth, hard, level finish which can be painted for the shake of appearance.
    The mortar used cement sand mortar or cement, lime and sand mortar used for finishing of wall, ceiling surface. The mortar is spread on the irregular surface of wall or ceiling and finish with the tool required for it.
    The most common thickness of plastering on wall plane surface is 10-12mm and on rough side of 9’’ or 4.5’’ wall is 15 mm. where as more thickness is required i.e. 20 mm or more than the plaster done in two coats, one is under layer coat and top layer is finishing layer. The mix usually adopted for cement plaster is 1:3, 1:4, 1:6 and sand used for plaster should not have fineness modulus less than 1.4 to 1.5. In case where only fine sand is available, the fineness modulus is increased by adding coarse sand in the required ratio.
    Laying of Plaster
    • Cement plaster on ceiling/Roofing:-The smooth surface of roof/ ceiling shall be roughened by hackling or pock marking with pointed tool up to 3mm deep at 5 to 10 cm distance. All resulting dust and loose particles shall be cleaned off and washed with water. After curing the slab surface a thin coat of cement slurry is applied before starting the plaster. After applying mortar on the surface, the plaster shall be finish to a true and plumb surface and to the proper degree of smoothness as required. The work shall be tested frequently as the work proceeds with a true straight edge not less than 2.5 meter long.
  • On walls:-In addition to general roughness in the masonry, the joints shall be racked out to a depth of 10 mm for providing key to the plaster. Dust and loose mortar shall be brushed out. Efflorescence, if any, shall be removed by brushing and scraping. The surface shall be than thoroughly washed with water, cleaned and kept wet before plaster is commenced. To ensure true thickness and a true surface, plaster gauges 15x15 cm shall be applied horizontally and vertically at 2 meter interval and truly plane to plaster surface. After that plaster mortar shall be applied on the surface and after words the plaster shall be finish to a true and plumb surface and to the proper degree of smoothness as required. The work shall be tested frequently as the work proceeds with a true straight edge not less than 2.5 meter long. All horizontal lines and surface to be checked with level and all jambs and corners with a plumb bob as the work proceed.
Precautions to be taken at the time of plaster
  • Fix all the fittings of electric pipes, water supply pipes, and electric boxes etc. properly as per drawing /requirement before starting the plaster work.
  • Fit all the pipes so deep into the walls that the pipes can get proper thickness of mortar on them to avoid cracks in plaster surface.
  • Make proper bond between the background and the plaster coat. Make surface of the wall clean, free from all racked mortar and dust etc. with the help of iron brushes.
  • Wash and water the surface for 24 hours before the plaster is applied. Fix the reference mark (BUNDAS) on the walls truly in lines and plumb before starting the plaster. Ensure that all the edges of openings are round. Check the plaster frequently with straight edges and plumb bob.
  • Do proper curing for at least 15 days to harden the plaster sufficiently and avoid the damage when watered.
  • Mark proper dates on the plastered surface for proper curing .
  • Protect all the fittings on the wall.
  • Clean any splash of mortar on a finished surface immediately on completion of the work.
Tue Sep 01, 2020Post  #2
NormaG
NormaG
Here is the pretty interesting updates are available by the construction point of view which would be pretty helpful as well. The people who are going to start the new construction of their house they should follow the key points. I really amazed to have college-paper.org reviews updates at one place keep it up to share more.
Thu Sep 03, 2020Post  #3
Plasterwork is construction or ornamentation done with plaster, such as a layer of plaster on an interior or exterior wall structure, or plaster decorative moldings on ceilings or walls. This is also sometimes called pargeting.
3992
4629
time for paint and wall putty
2035
Alternate for River Sand
Last answer on 2/25/2013 2:02:46 PM. by RENJI. Forum started by RENJI
2085
CEMENT PANI - Plaster Works
3651
2221
Last answer on 5/24/2021 4:53:02 AM. by Abhishek Garg (Builder & Engineer). Forum started by vamsi
35211
9158
3041
3383
Checklist for Painting Work
Last answer on 9/26/2011 12:10:51 PM. by dharmalingam. Forum started by vikram khot
5223
3476
labour charges rates
2521
construction const
2136
READY MIX PLASTER
2033
2925
2198
Usage of M-Sand in Bangalore
3010
M-Sand for Plastering
3398
Bathroom Cleaning Tips
2929
Plaster
3048
Plastering
1925
2007
PPC and OPC cement
11300
1871
suggest for exterior
7006
9158
1878
OPC and PPC cement
2159
2012
coarse aggregate
1826
Nice
2438
Gypsum Plaster Vs S/C Plaster
2174
Outer Plaster
2997
2735
putty work on walls
2237
2828
2033
Gypsum
Checklist for Cement Plaster
Specification of ‘Plastering’
How to clean plaster ceiling?
Plastering
Plastering
