Thu Oct 14, 2010Total posts : 2
nith_piyush
nith_piyush
Topic: Please tell me what quantity of water should be added for slab casting in concre
Please tell me what quantity of water should be added for slab casting in concrete of ratio 1:1.5:3 and 1:2:4
Thu Oct 21, 2010Post  #1
Dear Piyush
   The quantity of required water is following.
1.Water for nominal mix concrete shall generally be equal to 5% by weight of aggregate and 30% by weight of cement.
2.Generally for vibrated concrete the quantity of water will be less by 20% but the actual quantity shall be determined by the field test for slum.
3.For one bag mixture, 32 liters of water is required and the ratio will be 1:2:4
4.For one bag mixture, 30 liters of water is required and  the ratio will be 1:1.5:3 , for more information about cement concrete please visit gharexpert construction section concrete sub section.
Sun Oct 12, 2014Post  #2
Dear,
for 1 cum slab 180 lit water is required for m-20 grade concrete
2869
FOR 250 SQ FT R-B-C SALB RATE
2093
My House is north facing please tell which is best direction for installing wate
Last answer on 11/19/2012 11:30:26 AM. by Amit Hasija. Forum started by Anuj Anand
1842
stair construction
Last answer on 3/7/2017 9:56:24 PM. by S L Gupta (Civil Engg). Forum started by Sanzana Hosen
1974
casting of slab
Last answer on 7/29/2014 12:58:28 PM. by S L Gupta (Civil Engg). Forum started by ishaan
2896
Terrace water proofing
2097
about roof leveling
Last answer on 6/23/2015 12:59:46 AM. by JAI PRAKASH. Forum started by narendra adkine
191900
3258
3156
Basement waterproofing
Related to Sunken Slab
1751
how much cast
Last answer on 12/11/2020 12:20:05 PM. by JAI PRAKASH. Forum started by PRAVEENKUMAR
17
iNtEr cAst lOvE mArRiAgE 91-8769373431 lOvE BaCk SpEcIaLisT
Last answer on 12/14/2024 1:34:53 AM. Forum started by rupeshji
17
,,!iNtEr cAst lOvE mArRiAgE 91-8769373431lOvE bAcK sPeCiAlIsT
Last answer on 12/14/2024 1:51:46 AM. Forum started by rupeshji
InTEr cASt 918769373431 @ LoVe PrObLeM soLutiOn
Last answer on 12/14/2024 1:57:32 AM. Forum started by rupeshji
15
Last answer on 12/14/2024 11:26:13 PM. Forum started by rupeshji
18
,,!iNtEr cAst lOvE mArRiAgE 91-8769373431 lOvE bAcK sPeCiAlIsT
Last answer on 12/14/2024 11:32:23 PM. Forum started by rupeshji
20
InTEr cASt 918769373431 @ LoVe PrObLeM soLutiOn *itaLy
Last answer on 12/14/2024 11:34:52 PM. Forum started by rupeshji
Reasons of dampness
Centering
