Plinth Area Rate per SQ.m of Building
Tue Sep 08, 2015
pratham158
Topic: Plinth Area Rate per SQ.m of Building
While finding out preliminary estimate of building what should be Plinth area rate per sq.m of building should be considered??? ( for residential & commercial buildings)
Tue Sep 08, 2015
Plinth area rate is linked with the Drawings of the building and specification used in construction and type of building i.e house, office, store etc.However for general specification the rate may be from Rs 10000-00 to 12000-00 per sqm.
Tue Sep 08, 2015
12-13k / sq.m
3938
Last answer on 10/25/2014 8:46:00 PM. by
narendra adkine
2085
Last answer on 1/8/2018 11:06:10 PM. by
ravikumar
4752
CONSTRUCTION COST OF 3 STOREY BLDG
Last answer on 7/4/2020 2:47:14 AM. by
kavi77
shakirk78
3840
Last answer on 5/5/2014 12:57:31 PM. by
lb sharma
5684
What is the cost of the emulsion paint per sq ft as per today's market rate?
Last answer on 2/14/2013 11:17:01 AM. by
Jemimmarichardson
Rani
3212
labour cost
Last answer on 4/9/2021 5:38:18 AM. by
narendra adkine
2022
Last answer on 11/10/2016 5:24:45 PM. by
Sagar
3494
labour charges rates
Last answer on 7/4/2020 2:03:37 AM. by
SAGAR
18412
Last answer on 11/5/2021 3:48:21 AM. by
Quovino
Last answer on 6/9/2016 11:04:10 PM. Forum started by
Vignesh
3667
Last answer on 10/13/2014 8:29:35 AM. by
sudhir singh
22204
Difference between plot size area, built-up area, plinth area
Last answer on 3/17/2016 12:21:27 PM. by
vamsi
5818
Industrial shed construction
Last answer on 1/8/2022 4:18:30 AM. by
shikha Chetal
6056
Last answer on 10/18/2014 4:08:18 AM. by
bhatu
Last answer on 6/9/2015 4:30:39 PM. Forum started by
Debi Prasad Nayak
13838
rcc rate per cubic meter
Last answer on 10/20/2014 12:03:29 PM. by
anks
2009
How to select Mason
Last answer on 2/3/2022 11:34:26 PM. by
syedwajidali
35243
Last answer on 7/29/2019 2:40:51 AM. by
laxminarayana.s
2447
False Ceiling
Last answer on 9/1/2015 2:55:46 AM. by
Vijay
2485
What is acre
Rugs for Living Room
Orientation of Building
What are various termite control methods?
INITIAL INSPECTION AND REPORT requires a complete thorough inspection of the buildings and surrounds, and a detailed w..
What is recommended size and shape of building for the protection in earthquake prone areas?
All parts of a building should firmly be tied together and stiffly braced at corners in such a manner that the whole s..
