Home -> Forums -> Construction -> Start Construction -> Plot 1200 Sq. Ft, Need suggestions for constructing a house.
Tue May 10, 2016Total posts : 1
Raja Krishnan
Raja Krishnan
Topic: Plot 1200 Sq. Ft, Need suggestions for constructing a house.
Hi Experts,
I am a new comer here. And new to construction field too. Shortly I am planning to construct a house and want to take complete charge of the project, Ground plus 3 floors in Bangalore. I need suggestions before starting.
Plot is 1200 Sq. Ft (30x40). Our plan is for a Ground plus 3 Floors with ample parking space.
1.What is the maximum area that we can construct the house?
2.Is the basement a good idea or not? any alternative suggestions?
3.How much
material required for each floor construction?
4.What should be the size of pillars and the maximum distance between two pillars?
Kindly share your expert advise and guide me.
Wed May 11, 2016Post  #1
Dear Raja
 1    You can take the  information about the area of construction from your municipal corporation.
2. Basement is good idea according to my view as cost of land is very high.
3.For material calculation first prepare the drawing of building and finalize the specification after that material can be calculated.
4. The design of R C C columns, beams and slab is designed according to load bear by them taking factor of safety from earth quack, bearing capacity of soil etc in consideration. For basement and other 2 stories it is better to take design from structural engineer.
 For more information See the link below
Delete
3373
forward me some house plans(1200-1500 sq ft)
Last answer on 5/14/2011 9:57:26 AM. by mani. Forum started by BINU SAMUEL
1931
need help/advice to construct residentail house on 100 sq yd plot in hyderabad
Last answer on 2/21/2017 12:44:08 PM. by S L Gupta (Civil Engg). Forum started by Kamal
2224
3830
4556
Last answer on 7/2/2020 10:07:35 PM. by S L Gupta (Civil Engg). Forum started by Pavan Kumar V
3129
3083
14650
Construction cost in Mysore 1200 sqft
Last answer on 5/27/2015 12:46:44 AM. by JAI PRAKASH. Forum started by Arun
2745
3542
Contruction Tool
2462
Painting for the house.
Last answer on 8/12/2010 4:54:41 PM. by Veena Gil. Forum started by chandana
3414
I am in need of lay out plan foo house.land area 600 sq mtrs.60 ft x 90 ft.
Last answer on 8/3/2012 2:05:24 PM. by Ar. Manoj Ralen. Forum started by viqar idris
14312
20 sq ft and 50 sq ft how can i make house with vastu
Last answer on 12/24/2012 3:50:59 PM. by S L Gupta (Civil Engg). Forum started by saravanan
3164
I want to know the budget for constructing a house of 600sq.ft(G) and 900 sq.ft(
Last answer on 12/31/2020 2:22:31 AM. by narendra barde. Forum started by vidhya
1629
reg plan for 1200 sq.ft.
Last answer on 3/5/2016 10:23:34 PM. by JAI PRAKASH. Forum started by pmlaks
2681
i have 600 sq ft plot at nandhi layout bangalore opp to devi temple , between pl
Last answer on 7/30/2014 10:56:32 AM. by S L Gupta (Civil Engg). Forum started by balakrishna
1181
3310
What is acre
Proper
Why
