Home -> Forums -> Vastu -> Drawing Room -> Plot shape as per Vastu
Wed Feb 18, 2015Total posts : 8
Sanjeev
Sanjeev
Topic: Plot shape as per Vastu
The plot I am looking at is Go-mukhi, which seems OK. But there's an projection towards North-west, which is not good, and inauspicious as per Vastu since the projection is towords the North around15-20degree
Two questions :
1. My question is that is that a problem if I am not going to construct any part of the house in the projection. This I ask since I get a clear rectangle of 40*60 with 40ft being the front(east facing). Will this be considering inauspicious
2. If needed, as a remedial action a wall can be constructed to cordon off the projection, will this be enough to rectify the Doosh.
If some Vastu expert can advice me if building a small temple there will help or some other rectification suggested
Thu Feb 19, 2015Post  #1
       for better result please consult with a Vastu expert who can give you exact  solution .if you want any plan and any construction related services contact us support@gharexpert.com.
Fri Feb 20, 2015Post  #2
Please consult with a Vastu expert.
Fri Feb 20, 2015Post  #3
Upload the plan of open plot mentioning the roads[which face],
shape of plot and dimensions.
Mon Feb 23, 2015Post  #4
Pavan
Pavan
Hello Sanjvee,
Without Plan it becomes difficult to analyze and property, request you to share the plan.
Regards.
Pavan Matkar
Tue Feb 24, 2015Post  #5
Sanjeev
Sanjeev
Post subject: Here are the details
Thanks to all for taking time out to address my question. I just uploaded the plot picture, please refer attachment and comment. Please note that
1. The entrance is from the East, with East facing 35ft and the West side 42ft
2. Length is approx. 60ft
3. Am planning to construct perfect rectangle of 30*40ft Ground+First floor
How does the plot as per Vastu?
Also since I am NOT going to construct anywhere near/in the projection area does it make it OK as per Vastu?
 If it' a concern just cordoning off the wedge and making it perfect rectangle of 35*60 help.
Or please suggest remedial action also.
Thanking you in advance
Attachments: Vastu-Plot.JPG Tue Feb 24, 2015,&n
Tue Feb 24, 2015Post  #6
Hi Sanjeev,
Yes, you are right make it right rectangle 35*60.
divide it with compound wall and use for other purpose like plantation.
(VastuExpert)
Wed Feb 25, 2015Post  #7
Pavan
Pavan
Hello Sanjeev.
After making the plot rectangle, plant Bamboo in the NW excess area.
NW is governed by Wind element and Bamboo would be best at this side.
Bamboo you can use in combination with other plantations too.
Regards.
Pavan Matkar
Thu Feb 26, 2015Post  #8
Sanjeev
Sanjeev
Pavan & Nageshwar, thanks for your inputs and quick response. Addresses my concern big-time
Also any other Dos and Don'ts please let me know
Thanking you
Sanjeev
29049
9310
MY HOUSE IS NORTH FACING.IT IS ALSO L SHAPED,EXTENDING SOUTH WEST.AS PER VASTU W
Last answer on 8/23/2012 4:53:22 PM. by Ravi. Forum started by mahender
4145
I would like go for a OCTOGONAL shaped Cottage is it OK as per Vastu?
Last answer on 4/19/2012 12:30:48 PM. by Kanhaiya. Forum started by girishmani
4371
Last answer on 4/25/2014 2:55:51 PM. by seema tyagi. Forum started by PANKAJ
4025
Last answer on 7/8/2019 11:19:25 PM. by S L Gupta (Civil Engg). Forum started by Ashish Ranjan
13504
Last answer on 7/3/2020 11:13:29 PM. by S L Gupta (Civil Engg). Forum started by Vijay
7537
3306
2481
i have a plot 31*40" west facing,in HOWRAH .this plot northen side have a water
Last answer on 1/15/2012 7:50:36 PM. Forum started by sovan kumar sett
My 'L' shaped plot (10' wide entry stretching upto 40' and thereafter, 40' bread
Last answer on 10/29/2012 11:08:58 PM. Forum started by sekar
2041
Last answer on 11/8/2021 3:19:54 AM. Forum started by sekar
1812
can a plot be purchased which a curving road in front giving it a kite shape
Last answer on 8/21/2015 12:18:38 PM. by Nageshwar. Forum started by virendra
2029
Last answer on 11/23/2015 1:58:12 AM. by JAI PRAKASH. Forum started by POSAM BHASKARRAO
5254
Last answer on 9/1/2015 2:54:33 AM. by JAI PRAKASH. Forum started by r k khare
3300
Last answer on 8/11/2017 2:13:58 AM. by HOME. Forum started by Mitesh
2468
My plot Size 30X57 west side road 30 Feets and south side 56 feets, please sugge
Last answer on 2/27/2015 4:09:15 AM. by JAI PRAKASH. Forum started by Lakhvinder
2300
i need house plan for 23*47feet east view
Last answer on 12/4/2014 12:51:39 AM. by JAI PRAKASH. Forum started by kuldeep1
2053
i want to purchase plot having rectangular size two approach road east and west
Last answer on 9/27/2014 10:49:59 PM. by Nageshwar. Forum started by Deepak Fuke
1944
i want construct my home plot size 23x56 as per vastu and minimum cost so pls su
Last answer on 10/3/2014 3:12:07 PM. by Navneet Jharia. Forum started by jugal kishore
3676
3086
2316
2345
3406
2265
5121
1845
7104
2554
2143
1723
1821
1833
2073
5822
2676
7305
7537
2704
vaastu
Vastu for Kitchen
Children
Children Room Vastu Tips
