Outdoor
Plumbing works
Plumbing works
Wed Jun 10, 2015
manjula
Topic: Plumbing works
Hi, want to knw when plumbing works can be started...whether before plinth beam PCC (for toielts) or can be done later
Tue Jun 16, 2015
It can be done later.
3397
Bathroom Cleaning Tips
Last answer on 6/10/2019 1:04:58 AM. by
jaswinder Singh
Nitesh Patel
1965
electrical and plumbing work
Last answer on 12/11/2013 11:20:51 AM. by
neelam rathi
1781
My house is under construction and i have to go for plumbing therefore i want to
Last answer on 9/17/2014 10:59:54 PM. by
Avinash Sharma
2592
JOINERY WORKS
Last answer on 12/11/2013 11:18:00 AM. by
PLUMBING
Last answer on 6/8/2016 1:29:11 PM. by
Last answer on 8/8/2016 2:21:56 PM. by
Balu Menon
2223
how to calculate plumbing material for any project
Last answer on 10/5/2014 11:19:25 PM. by
3686
cost of plumbing,sanitaion,electrical as %of civil work
Last answer on 11/16/2021 12:22:16 PM. by
muralibgowda
naina
2466
Last answer on 6/24/2013 3:10:11 PM. by
kk
1826
Last answer on 7/18/2016 11:26:37 AM. by
2132
plumbing
Last answer on 7/3/2019 12:32:56 AM. by
space parameter for sanitary fittings
Last answer on 1/23/2016 8:28:13 PM. by
sandeep yadav
1820
Last answer on 7/3/2020 11:35:37 PM. by
Ganpat B Chaudhary
4443
lobar work quantity
Last answer on 2/21/2021 12:21:16 AM. by
D A VRAO
shaik khaja nayab rasool
3105
Last answer on 10/5/2020 10:59:59 PM. by
DEVANSU
38673
Construction Cost of individual house in Kolkata?
Last answer on 7/18/2020 2:34:38 PM. by
Ravikant Mishra
pritam
2515
Cement
Last answer on 7/2/2020 10:15:16 PM. by
ferous
2157
Last answer on 12/26/2014 1:00:45 PM. by
Last answer on 1/23/2022 3:40:26 AM. by
Steel calculation
Vamshidharreddy
1758
Last answer on 1/25/2022 8:44:50 PM. by
Last answer on 8/21/2021 4:42:29 AM. by
PR Jawahar
6354
Last answer on 8/21/2021 4:40:29 AM. by
shriramk1986
PR Jawahar
11377
Last answer on 6/25/2021 6:30:23 AM. by
shankar
10720
Life span of RBC lintel roof
Last answer on 2/22/2021 11:28:18 PM. by
Mohit Kumar
jaachak
2090
Foundation
Last answer on 2/9/2021 1:27:59 AM. by
Pooja
3569
R.C.C. column in Sqft
Last answer on 7/4/2020 2:03:17 AM. by
ringwang
1587
Last answer on 5/3/2016 11:27:23 PM. by
Test
New 4 storey building design
Last answer on 3/5/2016 10:15:22 PM. by
Raidang
1904
earth filling under floor
Last answer on 9/26/2015 6:31:04 AM. by
ARVIND GOYAL
ARVIND GOYAL
1773
want a parking
Last answer on 11/22/2013 12:57:04 PM. by
vinod kumar
2403
Last answer on 2/26/2013 11:22:44 AM. Forum started by
nasad
2268
Last answer on 12/24/2011 4:12:24 PM. by
ravi at Dalmia
raj10
2565
foundation plan.
Last answer on 12/15/2011 2:31:13 PM. by
Ishmael Mphande
Patrick Salasini
2624
Last answer on 12/6/2011 7:58:37 PM. by
Manish
Manish
2501
Re-Construction
Last answer on 8/8/2010 11:31:05 PM. by
harbans singh sekhon
amit saini
3013
cracks in walls
Last answer on 5/25/2010 2:07:18 PM. by
ndevendra
Checklist for Plumbing
Sewerage & Plumbing System
Which are space parameters for plumbing and sanitary fittings?
The following are various space parameters for plumbing and sanitary fitting:
Checklist for Painting Work
