Home -> Forums -> Construction -> Start Construction -> Plz guide us about no of floor we can contruct
Sun Apr 03, 2011Total posts : 1
Bhaskar
Bhaskar
Topic: Plz guide us about no of floor we can contruct
My father is constructing a house in ASSAM, Dibrugarh Distt (india) and its a 2000 sq ft house. and he had used 12 mm rod (4) and 9 mm rod (2) in the poles and uptil now he had made ground floor but now we are planning to go for first floor. but i want to know how many floor we can construct safely...so please advice.
Mon Apr 04, 2011Post  #1
Dear Bhaskar
                   The size  and M S Steel bars in RCC Column are depend upon the load bear by the RCC Column, span i.e. distance between the columns are also affects the loading. It is not possible to tell without studing the drawings of the house. If you want to clearify  this then send the drawing.
3466
Kindly guide us for which type of flooring like marble, vitrified tiles is suita
Last answer on 4/12/2010 4:08:33 PM. by M Jindal. Forum started by Sanjay jain
2372
2269
we have 2 kitchens,2 entrance doors facing west since partion having door plz su
Last answer on 9/24/2010 7:41:25 PM. Forum started by pradeep
3162
plz send me vastu complaint floor plan for 2 floor plot having dimensions of 30"
Last answer on 2/21/2022 6:22:21 AM. by seema tyagi. Forum started by ashok
2081
I WANT TO CONTRUCT DOUBLE STORY HOUSE IN 25X55 EAST FACING PLOT PLEASE GIVE YOU
Last answer on 11/3/2016 12:09:48 PM. by JAI PRAKASH. Forum started by PRAMOD
1963
good evining and good day my polot size 31*72 feet plz need me floor map
Last answer on 6/9/2015 11:09:22 AM. by seema tyagi. Forum started by Muhammad Iqbal
1699
SIR, I WANT TO CONSTRUCT MY HOUSE 3RD FLOOR. TODAY THER IS G 2FLOOR.I WANT EXTEN
Last answer on 3/5/2016 9:50:33 PM. by JAI PRAKASH. Forum started by cvsatav
2421
start construction Steel use
2227
UNIT
Last answer on 7/3/2019 12:34:37 AM. by S L Gupta (Civil Engg). Forum started by sanjoy koley
1775
water pond or waterfall
Last answer on 2/8/2016 11:17:04 AM. by S L Gupta (Civil Engg). Forum started by SACHIN
2342
House contructed in the plot i have purchased has a southwest corner extension(p
Last answer on 12/11/2021 1:01:47 AM. by sabina vanjani. Forum started by subrahmanyam
2435
I want to contruct first floor on already existing ground floor with a plinth ar
Last answer on 11/5/2012 3:30:44 PM. Forum started by parvathi
2892
Last answer on 11/5/2012 5:44:56 PM. by krishna. Forum started by parvathi
1890
Hi plz tell me any good vastu consultant plz
Last answer on 5/19/2016 10:18:22 PM. by mukesh. Forum started by seema
1966
Over Head Water Tank
1905
earth filling under floor
1514
Can you guide wether my flat is vaastu compliant for which I want to upload floo
Last answer on 4/8/2015 11:13:38 PM. by JAI PRAKASH. Forum started by JATIN GHELANI
10312
900 Sqft column required
Last answer on 7/21/2021 11:11:14 AM. by S L Gupta (Civil Engg). Forum started by Shivaraj
1618
Sir I have 40*60 plot I want 4 bhk on first floor plz send me a plan
Last answer on 10/10/2016 10:58:45 AM. by Beenu Phogat. Forum started by Aejaz Ahmed
3310
2059
Buying
Buying Guide for Garage Door
Vastu for Kitchen
Terrazzo
Tips for maintaining Flooring
Proper maintenance of flooring is required to retain the beauty of floors and home as well. The flooring preserved nicel
Flooring
Flooring for Kids Room
The flooring material that you choose has to be comfortable, easy to clean, and right for you and for your kid. It has..
Epoxy
Epoxy Flooring
Epoxy flooring can be defined as several layers of any type of epoxy resin that is applied on a floor surface. This ty..
Italian
Italian Marble Flooring
Basement Flooring
