Home -> Forums -> Construction -> Start Construction -> Pre coated sheet roof
Tue Jun 12, 2012Total posts : 2
MM JASSAL
MM JASSAL
Topic: Pre coated sheet roof
I am constructing a house in Una Distt. of HP. I intend to install roof of precoated sheets. Kindly advise as to how to beat the heat as the summers are very hot.
Mon Jul 09, 2012Post  #1
Post subject: Ja
Dear Jassal
For insulation of walls and roof please see the link below                                           at the gharexpert website
http://www.gharexpert.com/articles/Finishing-1607/Thermal-Insulation-Home_0.aspx
Mon Jul 09, 2012Post  #2
Ar. Manoj Ralen
Ar. Manoj Ralen
Now a days there are treatments available in the market where you can put reflective paints on the roof top that would reflect the heat back.  You can also install insulation sheets inside the home on roof if you intend to do false ceiling.  But do go ahead with such treatment as it would reduce the temperature by at least 5 degrees.
8419
Roof Beam crack
1381
what would be total expense to install rubber sheet on roof of 780 sqft
Last answer on 9/24/2016 12:49:20 PM. by S L Gupta (Civil Engg). Forum started by DHIRENDRA
2829
2758
Iron Sheet Roofing
Last answer on 6/2/2012 7:25:01 PM. by skjain20002000. Forum started by Mr Marea Itaia
1432
I am planning to build a cost effective house. I like to explore use of metal sh
Last answer on 12/8/2016 12:32:51 PM. by S L Gupta (Civil Engg). Forum started by sasi raman
3068
Painting
2084
CEMENT PANI - Plaster Works
2991
Wall Putty ,primer and paint
2139
Roof insulation
Last answer on 9/20/2014 12:13:54 PM. by S L Gupta (Civil Engg). Forum started by sb
2133
Sir I am having a rcc sheet roof of 60*12 feet now the sheets was gone I want to
Last answer on 11/5/2014 12:31:16 AM. by JAI PRAKASH. Forum started by srikanth
2151
seal coat on roof
Last answer on 9/19/2010 11:16:18 PM. Forum started by viswanath
4952
3283
Wall Putty on exterior wall
1679
Roofing costs with corrugated metal sheets
Last answer on 4/4/2015 12:25:19 PM. by S L Gupta (Civil Engg). Forum started by Sunil
1879
Fiber sheet on the roof
Last answer on 5/1/2015 1:38:54 AM. by JAI PRAKASH. Forum started by VIJAY
1448
Roofing Cost of HINDALCO STEEL SHEETS
Last answer on 5/3/2016 11:35:20 PM. by JAI PRAKASH. Forum started by sira
1532
Cement Sheet Roof
Last answer on 5/6/2013 11:02:16 AM. by S L Gupta (Civil Engg). Forum started by Narayanan
2081
Last answer on 10/23/2010 3:33:17 PM. Forum started by sandeep Dholakia
1981
north to south face 4 bedroom plans 1800 sheet 48 chorai 35 lainth map images
Last answer on 2/25/2015 9:23:56 AM. by seema tyagi. Forum started by neelam
3309
2133
2059
Iron
Iron Sheet Roofing
ACC
ACC Sheet Roofing
Surface
Cooper
Roof Flashing
Is the ceiling of your house leaking? Apply roof flashing technique to prevent water leakage from the roof. Roof flash..
