Dampness
Mon Apr 12, 2010
sujani
Topic: Protect your home from Dampness
what are the major failures that occurs after construction of building? what are the reasons for these failures? how to avoid those?
The comment above talks about the article
"Protect your home from Dampness"
Wed Apr 14, 2010
Post subject: Reply- major failure
Dear Sujani,
There are many causes of failure of building after construction; some of them are as under.
1.
Failure of foundation:-
There are many causes of failure of foundation such as:-
Defective construction.
Low bearing capacity
Inadequate design
Due to change in moisture shrinkage or swelling affects on the clay under foundation.
Compression of a soft layer in the ground as a result of the applied foundation loads
Soil softening
Due to heavy frost.
Back filling not done properly
Due to change in groundwater level.
Erosion caused by flood or heavy wind pressure.
Vibration from nearby construction
Hydrostatic Pressure
2. Failure of structural member i.e. RCC Column, Brick wall etc. These failures occur due to weak mix, faulty design, using salty water and careless in construction.
Failure of structural member i.e. RCC beams and slab is one of the major cause.
S.L.Gupta
Thu Jul 08, 2010
haritha
Post subject: Protect your home from Dampness
What is meant by sealing of walls? When and how is it done in the residential buildings?
Dampness-Construction Questions (35)
2126
Dampness problem: In my new home, the house adjacent to me has dampness in the w
Last answer on 6/22/2009 3:15:25 PM. by
George
2234
paint
Last answer on 6/30/2021 1:46:52 AM. by
jollyjodhaka
2103
I am planning to fix sunshade at my home to stop dampness. The problem is the su
Last answer on 12/29/2011 6:15:24 PM. by
rajesh
3291
Last answer on 12/6/2021 7:43:12 AM. by
Narender
husssain
3490
How to solve dampness in wall
Last answer on 11/17/2016 10:58:15 AM. by
Girish
Rajan
2362
dampness in corners at the junction of walls and floors
Last answer on 3/9/2011 12:14:27 PM. by
Nenni
AN CHORDIA
2379
dampness in bathroom,loft and staircase
Last answer on 8/19/2013 11:25:13 AM. by
Arun
2497
Protect your Home from Bugs
Last answer on 12/29/2010 2:52:39 PM. by
Nikita
trimbak
2530
Reasons of dampness
Last answer on 12/22/2011 12:46:29 PM. by
kamal hossain
1965
Last answer on 12/6/2016 1:58:54 PM. by
2031
Last answer on 1/28/2011 10:11:15 AM. by
Nikita
gururaj s sannakki
2143
how do you stop dampness in old buildings especially if it is due to burst conce
Last answer on 11/13/2010 8:21:32 PM. by
sangameshs
1748
Last answer on 1/12/2011 5:19:12 PM. by
Geetika
Geetika
2703
home security systems
Last answer on 7/3/2020 10:55:36 PM. by
farrukh tahir
2523
1793
Prtotect Cast Iron Cover on underground Tank & Manhole from Theft
Last answer on 10/25/2013 12:34:54 PM. by
Viral
1810
Last answer on 5/3/2016 12:15:59 AM. by
Rajput veer pratap singh
1886
kitchen Cabinets
Last answer on 12/17/2015 2:51:28 PM. by
ARVIND GOYAL
2290
Last answer on 1/5/2022 2:14:28 AM. by
Damp Proofing
Last answer on 12/31/2020 1:53:13 AM. by
Mike Perkin
VIPIN
3490
Girish
Rajan
1860
Last answer on 12/24/2015 4:06:01 AM. by
sushantsah
1491
Canada Goose Chilliwack Bomber much likewise
Last answer on 11/14/2015 12:37:51 AM. by
farofaschafer
2072
Last answer on 8/26/2015 11:23:20 AM. by
Last answer on 8/17/2015 1:04:41 PM. by
Walls are damp in rain
Last answer on 8/5/2015 10:51:47 PM. Forum started by
Last answer on 8/5/2015 4:33:46 AM. by
Damp
Last answer on 4/4/2015 7:00:17 PM. by
Jag
1920
Leaking Ceiling
Last answer on 8/25/2014 8:26:28 PM. by
sandipvora
2762
Last answer on 8/21/2014 2:44:43 PM. by
ADINATH
Anu Rajbanshi
1925
bathroom dampness
Last answer on 12/23/2013 12:21:54 PM. by
sunder
2570
Basement Leaks
Last answer on 10/24/2013 11:40:09 AM. by
Reasons of dampness
kamal hossain
2365
water treatment for walls
Last answer on 4/27/2011 7:37:34 PM. by
gajender pathak
1748
Geetika
Geetika
Which type of DPC recommended for the protection of dampness?
For residential buildings DPC consists of a layer of - 40 mm thick cement concrete 1:2:4 (1 cement: 2 Coarse sand: 4 g..
How to Protect Wood Furniture
Proper care and protection keeps wood furniture always appealing. If you want to maintain splendor of your wood furnit..
Protect Your Family from Dust
Termite Control
Have you protected your home from termites? Termites destroy household articles and create unhygienic conditions for i..
Reasons of dampness
Damp Proofing
