Home -> Forums -> Construction -> Security Locks -> Prtotect Cast Iron Cover on underground Tank & Manhole from Theft
Thu Oct 24, 2013Total posts : 1
Viral
Viral
Topic: Prtotect Cast Iron Cover on underground Tank & Manhole from Theft
I have underground Brickwall tank below parking area in my house. The same is covered with cast iron cover. Since the same is accessible from outside, I want to have expert opinion on how to protect the cover from Theft. Further since there is submersible pump in the tank, I want to protect both from theft.
Looking forward for expert opinion.
Thanks & Regards,
Fri Oct 25, 2013Post  #1
Dear Viral
            Make frame of angle iron and fix it with cement concrete and weld the hinges on the frame than on the other frame weld MS sheet and weld the shutter with hinges  and made the provision of locks.
Security Locks-Construction Questions (21)
5055
3119
2483
2186
2058
2119
2634
5207
2450
2003
Electrical Conduits
Last answer on 4/30/2014 3:32:30 PM. by ajaywahi. Forum started by ajaywahi
2186
2956
Need help for terrace room to cover iron bars (Picture Attached)
Last answer on 12/28/2012 11:27:53 AM. by S L Gupta (Civil Engg). Forum started by prabhjeet
3747
How to cast sloped/slanted roof, as our architect described inablity to use vibr
Last answer on 3/5/2013 12:11:16 PM. by S L Gupta (Civil Engg). Forum started by mrityunjay singh
1751
how much cast
Last answer on 12/11/2020 12:20:05 PM. by JAI PRAKASH. Forum started by PRAVEENKUMAR
1908
17
iNtEr cAst lOvE mArRiAgE 91-8769373431 lOvE BaCk SpEcIaLisT
Last answer on 12/14/2024 1:34:53 AM. Forum started by rupeshji
17
,,!iNtEr cAst lOvE mArRiAgE 91-8769373431lOvE bAcK sPeCiAlIsT
Last answer on 12/14/2024 1:51:46 AM. Forum started by rupeshji
15
InTEr cASt 918769373431 @ LoVe PrObLeM soLutiOn
Last answer on 12/14/2024 1:57:32 AM. Forum started by rupeshji
15
Last answer on 12/14/2024 11:26:13 PM. Forum started by rupeshji
2404
Security Locks for Home
Last answer on 12/31/2020 1:22:23 AM. by shimbhu dayal. Forum started by Rashmi
2142
Best Security System For Duplex Homes
Last answer on 9/3/2020 7:07:54 PM. by JAI PRAKASH. Forum started by rahulsharma
Bedding
Bedding Cover
Selection of Cushion Covers
Cushion covers are a great bonus to the interior of a home. They cover up your cushions and can superbly change the lo..
Basic
Basic home security tips
Vastu for Water Tank
Preventive
Swimming
Swimming Pool Covers
Pool covers become an important thing when the swimming season ends. As they reduce evaporation as well as protect you..
