Fine Aggregate
Tue Jan 10, 2012
Shrinivas
Topic: Purchasing Guidelines for Fine Aggregate/ Coarse Sand
how much sand, cement bricks and steel is required to construct a 1500 sq ft duplex house?
The comment above talks about the article
"Purchasing Guidelines for Fine Aggregate/ Coarse Sand "
Wed Jan 11, 2012
Post subject: Requirements of additional documents
GharExpert provide service for the construction cost estimate which
would give you the brick by brick cost calculation.
Detailed cost estimate pricing is based on the built up area of the
house and price slabs given below:
Up to 2000 sq.ft area= Rs.2.50 per sq.ft.
From 2001 to 5000 sq.ft area= Rs.2.00 per sq.ft.
From 5001 to 10000 sq.ft area= Rs.1.50 per sq.ft.
Above 10000 sq.ft area= Rs.1.00 per sq.ft.
For preparing the detailed cost estimate, We need additional documents from you:
3. Which type of shutters and wood is being used for doors and
windows? Would it be deodar wood, hollock wood, teak wood etc.
6. Do you have exterior elevation design and structural drawings
provided by your architect?
7. Please supply floor plans.
If you have this information and drawings then send them to
support@gharexpert.com
Fri Feb 15, 2013
zahir
Post subject: Purchasing Guidelines for Fine Aggregate/ Coarse...
What is the thickness of polyester membrane and how do we apply polyethylene(in what gauge) to SBS rubber.
Sat Sep 21, 2013
op kataria
I AM LIVING ON 3RD FLOOR.THE OWNER OF 2ND FLOOR WANTS TO CONSTRUCT 10FT BY 10FT BATHROOM.I HAVE TO BEAR 50% OF COST.COULD YOU PL. GIVE ME THE ESTIMATED COST.
Fine Aggregate-Construction Questions (21)
2012
coarse aggregate
Last answer on 8/10/2015 4:00:45 PM. by
satinder parshad
satinder parshad
2719
Last answer on 5/17/2014 12:39:31 PM. by
gaurav
Yousuf khan
1851
Last answer on 7/11/2011 12:00:45 PM. by
KALPANA
2245
about construction
simran
16073
robo sand vs natural sand
Last answer on 5/19/2014 11:46:14 AM. by
shaik khaja nayab rasool
3867
Last answer on 3/5/2016 10:06:54 PM. by
K M Sendhil
2349
Last answer on 7/11/2010 10:15:36 PM. by
Anil Kumar Mishra
satish singh
1608
Specification of Coarse Aggregate
Last answer on 1/23/2013 1:02:12 PM. by
S P Singh
2328
Roof flooring
Last answer on 1/17/2022 8:20:49 PM. by
ravi pachipala
1556
Last answer on 6/7/2017 12:20:58 PM. by
Sandeep Vidwans
2658
Last answer on 3/4/2013 12:25:11 PM. by
nasad
nasad
2336
Last answer on 9/19/2012 1:30:40 PM. by
r s rawat
mujahedsabb
2268
Last answer on 5/26/2012 8:18:55 AM. by
hafiz
2526
Last answer on 6/19/2009 8:57:08 PM. by
S.Krishnan
anil
3422
Purchasing Guidelines for Marble and Granite Stone
Last answer on 12/31/2020 2:29:42 AM. by
Sonu chaudhary
kavitha
3715
Last answer on 10/8/2014 8:42:33 PM. by
K S SHYAM SUNDER
1670
Last answer on 3/5/2016 10:38:42 PM. by
krishna
1304
Last answer on 5/21/2018 3:33:47 AM. by
VivekC
RAJAT BANGA
1767
vishal Thakur
2719
gaurav
Yousuf khan
3616
Can we use crushed Sand for house construction
Last answer on 4/8/2014 12:28:09 PM. by
Density of Coarse Aggregate
What is aggregate
There are mainly two types of aggregate:Fine aggregate and coarse aggregate. Let us know more about aggeregate in foll..
Aggregates of concrete and their density
In cement concrete aggregates occupy 75-80 percent volume of concrete, so you can say Aggregate is a major resource fo..
Coarse Aggregate consists of crushed, uncrushed or broken stones. Check the grading of sand for proper sizes.
Buying tips for Brick Blast
Buying tips for Cement
