Home -> Forums -> Construction -> Marble Chips -> Purchasing Guidelines for Marble and Granite Stone
Wed Oct 28, 2009Total posts : 15
kavitha
kavitha
Topic: Purchasing Guidelines for Marble and Granite Stone
i need to know which is better for flooring either granite or marble... i came to know that granite or marble wil create pain in the leg for older people when they walk on it for a long time....plz do let me know more about flooring.
The comment above talks about the article   "Purchasing Guidelines for Marble and Granite Stone "
Wed Oct 28, 2009Post  #1
kavitha
kavitha
Post subject: Purchasing Guidelines for Marble and Granite Sto...
i would like to know more about interior decoration for house.our house has 3 bedrooms with dress rooms and attatched bathrooms, hall,kitchen, dinning, pooja and sit out and portico
Fri Oct 30, 2009Post  #2
damodar
damodar
Please give me marble laying ideas with boarders and skirting with granite.
Fri Oct 30, 2009Post  #3
pravin
pravin
How we could identify the good quality green marble for Kitchen? What are the measure scale to identify it.
Wed Nov 04, 2009Post  #4
anand
anand
can i use marble for wall cladding, for front elvation,how it will look.
Mon Nov 16, 2009Post  #5
naina
naina
i am constructing on top of existing house ground floor. first floor has 4'parapet wall all over,one bedroom and bath and staircase,headroom and foyer. area to be built is 1780 sqft,- 2 bedrooms,2bath,kitchen,storeand utility.in addition 120sqft stairs leading to 2ndfloor, headroom and terrace needs to be built. builder is quoting 24lacs for all of this. providing flush doors, vetrified tiles in all rooms,ceramic tiles in bathroom, upvc door frames. he will use existing 4'feet parapet wall andbuild on top. is this rate correct
Sat Jul 24, 2010Post  #6
pravin ballamwar
pravin ballamwar
b,coz of space problem i have to build staircase in anticlockwise pls tell me what is bad effect as per vastu
Thu Jul 29, 2010Post  #7
geetanjali nitave
geetanjali nitave
what is 1)water cut granite 2)kerosene cutter
Sun Aug 15, 2010Post  #8
dhanasegaran
dhanasegaran
what is mean by flamefinish granite
Fri Aug 20, 2010Post  #9
rayhanaparvin
rayhanaparvin
Hi, May I know if you provide an engineer and masons for constructing house in Chennai
Thu Feb 03, 2011Post  #10
praveen
praveen
what precaution should take while laying crack marble
Fri Jun 03, 2011Post  #11
RAMNIK SOOD
RAMNIK SOOD
Need feedback about good and bad qualities of Sadar Halli granite
Fri Jun 03, 2011Post  #12
Dear Sir
       Sadar hali granite is cheap in cost in comparision to other granite. As the price indicates, it has some disadvantages , it is soft material and may absorb liquids (tea/coffee etc) and hence the color will fade. If you are planning for walls, it may not affect you.
Thu Jan 12, 2012Post  #13
deepak vak
deepak vak
caution b4 using granite/natural stone in homes. pls read the following links- http://en.wikipedia.org/wiki/Granite#Natural_radiation http://www.epa.gov/radiation/tenorm/granite-countertops.html http://nitishpriyadarshi.blogspot.com/2009/04/think-twice-before-using-radioactive.html
Wed Jan 25, 2012Post  #14
HPVO
HPVO
Hi, I have been told that the slab that I have used as my profile pic is some kind of stone however I have no idea what it is. It is 25mm thick, black/gray in colour and is easily scratched. Is anyone able to help me identify what it may be?
Sun Jan 13, 2013Post  #15
Sonu chaudhary
Sonu chaudhary
generally how check marble stone quality for purchasing
Marble Chips-Construction Questions (22)
why we use granite for our home and kitchen ,,
Last answer on 1/30/2014 2:34:24 PM. Forum started by Nikhil rao
3807
3351
Granite and Marble , Kota stone
Last answer on 2/7/2014 10:55:10 PM. Forum started by Nikhil rao
2569
2525
Natural Stone Flooring
Last answer on 7/3/2020 9:23:41 PM. by kevinlee. Forum started by Jenne White
1702
Last answer on 7/3/2020 11:20:06 PM. by S L Gupta (Civil Engg). Forum started by PCR.Manohar
2199
Is it necessary to see vastu before choosing granite stone for new home?
Last answer on 8/18/2012 10:05:41 AM. by Ravi. Forum started by Ganesan Perumal
1070
For porche area flooring, granite stone is slippery and kota stone prone to flak
Last answer on 7/4/2020 2:41:31 AM. Forum started by Surinder Singh
1961
inbuilt burner
Last answer on 7/4/2020 2:12:51 AM. by JAI PRAKASH. Forum started by ARVIND GOYAL
2336
Last answer on 9/19/2012 1:30:40 PM. by r s rawat. Forum started by mujahedsabb
1851
Last answer on 7/11/2011 12:00:45 PM. by S L Gupta (Civil Engg). Forum started by KALPANA
3494
2266
Last answer on 5/26/2012 8:18:55 AM. by S L Gupta (Civil Engg). Forum started by hafiz
2526
Last answer on 6/19/2009 8:57:08 PM. by S.Krishnan. Forum started by anil
1715
Appreciated if i could get some advice on using granite stone and the shade, sin
Last answer on 9/23/2010 11:58:18 PM. by Ar. Manoj Ralen. Forum started by cruz
3745
Last answer on 4/17/2010 3:17:53 PM. by moeen akhter. Forum started by shalu sachdeva
2207
I have purchased katni marble. There seem to be cracks which run for about 3 fe
Last answer on 7/3/2015 3:42:03 AM. by JAI PRAKASH. Forum started by sivaprasad
2052
kitchen slab
Last answer on 10/1/2021 1:38:44 AM. by Jam117. Forum started by ARVIND GOYAL
1622
proporcja które overpronated zostalo wykluczone
Last answer on 1/16/2017 3:07:42 PM. Forum started by farofaschafer
1601
How many sq feet marble needed in 1700 sq feet area with kitchen and two floor stairs.
Last answer on 10/18/2016 5:17:56 PM. by S L Gupta (Civil Engg). Forum started by Dheeraj Grover
1755
biggest confusion
Last answer on 12/29/2015 12:52:15 AM. by JAI PRAKASH. Forum started by sushantsah
Marble stone should be hard, free from any stain i.e. deep cut or mark on the surface.
Buying tips for Brick Blast
Buying
Buying tips for Cement
Italian
Italian Marble Flooring
Specification and Purchasing Guidelines of Marble Chips
Marble chips must be crushed mechanically and be free from marble dust and foreign matter.
MARBLE STONE
Marble shall be hard ,sound , dence, and homogeneous in nature with crystal in texture as far as possible.
Granite
Granite Countertops
A kitchen equipped with granite countertops looks amazing and improves the beauty of kitchen and your home as well. Th..
