Home -> Forums -> Construction -> Drainage , Sanitary System and Plumbing -> Purchasing Guidelines for Sanitary material and Precautions While Laying Sewer Pipes line
Sat May 26, 2012Total posts : 1
hafiz
hafiz
Topic: Purchasing Guidelines for Sanitary material and Precautions While Laying Sewer Pipes line
No,that information will give best solution to laying severage line.this matter is under study & installation in my home & i will ask more detail if necessary.
The comment above talks about the article   "Purchasing Guidelines for Sanitary material and Precautions While Laying Sewer Pipes line"
Sat May 26, 2012Post  #1
Dear Hafiz
              Ask freely when you want.
Drainage , Sanitary System and Plumbing-Construction Questions (39)
4077
drainage pipe line for toiletfor south facing house
Last answer on 1/19/2022 6:35:06 AM. by S L Gupta (Civil Engg). Forum started by ajitkumar
2931
1676
1498
Last answer on 1/17/2015 11:33:39 PM. by JAI PRAKASH. Forum started by mohit kumar
1613
What r the materials avaiable for hiding sanitary pipes and bath windows of a so
Last answer on 2/19/2014 12:24:30 PM. by S L Gupta (Civil Engg). Forum started by satish
5097
Stop Rats from entering In house via Drain pipe
Last answer on 6/10/2011 11:47:24 PM. by P. Panchal. Forum started by P. Panchal
2850
1992
where we purchase railling material
Last answer on 10/4/2012 12:53:15 AM. by kamal. Forum started by Rajesh
1826
1525
2231
sewage pipes
2101
1619
2399
Sanitary Piping
Last answer on 5/17/2011 11:54:05 AM. by P. Panchal. Forum started by Gautam Aggarwal
What are requirements of drainage and sanitation for dwelling area covered with individual?
Last answer on 6/20/2013 5:14:02 PM. by Sandip Kar. Forum started by g.s.rajan
2626
How to hide Rain water pipe
4836
3589
Per Sq:ft rate for flooring
1726
Hello i am going to install electrical pipe line for the house, i need your help
Last answer on 2/14/2013 11:16:40 AM. by S L Gupta (Civil Engg). Forum started by Pradyumna Lal Pradhan
1887
tap Connection
3628
sunken slab
2508
How to hire a plumber
3499
1676
2321
3863
flush toilet
1960
4722
Cost estimation for sump tank
2221
water supply
2043
Underground Water storage
2231
sewage pipes
2253
commode & flush type
1949
WC issue
5629
Over-Head water Tank
2340
Vastu for septic tank
2484
2474
Septic Tank Design
3387
3755
position of septic tank
General
Guideline for laying DPC
Buying tips for Brick Blast
Buying
Buying tips for Cement
