Wed Sep 19, 2012 | Total posts : 2 |
| Topic: Purchasing Guidelines for 'Cement and Bricks'
I need to know the daily prices of building material, in order to plan and start construction.
pls advise me where can i get daily building material price?
The comment above talks about the article "Buying tips for Cement" |
Sat Sep 06, 2014 | Post #1 | karthik
Join date: Sep 2014 | Post subject: Buying tips for Cement
hi,
I plan to build house with promotors and their specification for 895sq.ft build area without pillars.
The items of work will be as follows :
I) Foundation & Basement
1. Earthwork excavation for Column footing 3’6” x 3’6” up to 5’0”
2. Plain cement concrete 1:5:10 using 11/2” metal for foundation
3. Reinforced cement concrete 1:2:4 using 3/4” jelly for column
depth.
base to a thickness of 6”.
footing, column, grade beam, etc., as per design. It includes the
barbending and centering etc., (STUB COLUMN METHOD)
4. The basement wall will be constructed by brick work and inside walls
will be plastered.
5. The basement height will be fixed as 3’-0” from existing ground
level.
6.Gravel filling inside basement including well ramming and
consolidation will be done.
7. Flooring with plain cement concrete 1:4:8 using 11/2” metal to a
thickness of 4”.
II) Super Structure
1. Brick work main wall 9” tk in C.M. 1:6 & Partion wall 4.5” tk in
C.M 1:4 using chamber bricks for superstructures as per working
drawing details.
2. Reinforced cement concrete 1:2:4 using 3/4” jelly for column, lintel
beam, roof beam and roof slab etc., as per detail. It includes the
3. Ceiling plastering will be finished in C.M 1:3 and C.M 1:5 by using
trowel and sponge.
4. Wall plastering will be finished in C.M. 1:5 by using trowel and
sponge.
5. Parapet wall 2’6” height will be constructed with 4.5” brick wall.
6. Weathering course by brick jelly and top will be finished with cement mortor flooring.
III) Floor finishing and Wall finishing:
1. Floor finishing:
a) All rooms in all Floor : Vetrified tiles @ 45.00/Sft
b) Toilet : Ceramic tiles @ 30.00/Sft
c) Entrance steps : Green Marble @ 80.00/Sft
d) Portico and outer staircase steps : Eurocon tiles @ 30.00/Sft
2. Wall finish:
a) Toilet walls upto 7’0” Height : Glazed tiles @ 45.00/Sft
b) Kitchen walls upto 4’0” Height : Glazed tiles @ 45.00/Sft
c) Skirting for all other walls in 3” Height : Vetrified tiles
d) Kitchen Table top : Green marble @ 80/Sft
e) Kitchen Stainless steel sink (Rs.1000/Nos)
IV) Joineries
1.Doors :
a) For Main door :Wooden door with paduk 5”x4”
frames and 11/2” shutters.
b) For Other doors :Flush doors with sal wood 4”x3”
frames.
c) For toilet doors :PVC Door with frame ( Rs.1500 per nos)
2. Windows & Ventilators :
a) For Windows & ventilator : UPVC window & ventilator with grill
3. Staircase handrail : Steel handrail. (Outer)
4. Locks
a. Maindoor Lock - Brass Lock (Rs.1500/Nos), Brass Hindges &
Brass towerbolt.
- 3 -
b. All other doors & Windows are powder coated lock , I-max
Hindges & Towerbolt.
V) A. Painting works
1. Inner walls will be finished with one coat of primer over a coat of
Plaster of Paris (POP).
2. Outer walls will be finished with one coats of Cement paint (ACE/Berger
or equivalent) over a one coat of Kottayam white cement.( standard
colour used for all villas)
3. Main door will be finished with polishing.
4. All other Doors & Windows grill will be finished with two coats of
enamel paint.
B. Electrification arrangements:
Concealed conduit wiring using PVC pipes and ISI brand cables for light,
fan and plug points with Indo asian switches with steel boxes will be provided for
all rooms.
UPS and Safety alarm works will be charged extra as per the market value.
C. Plumbing and sanitary arrangements:
Plumbing pipe line shall be provided by using CPVC pipes for inner and
PVC pipes for outer lines.
This work includes Plumbing sanitary fittings (ISI brand).
My doubt is whether its safe to go for pillar construction or this is save. | |
Thu Nov 20, 2014 | Post #2 | r s rawat
Join date: Nov 2014 | Post subject: Buying tips for Cement
what are quality reviews of cci cement any expert opinion pl tell | |
Articles that might interest you! | | Buying tips for Brick Blast You need to know these tips to buy Brick Blast for the construction of your home or commercial building. | | Buying tips for Cement A good home construction starts with good raw material procurement. Let's start with cement | | Purchasing Guidelines for Cement Manufacturing date, grade and type play vital role in purchasing right cement and there should be no lumps in it. | | Guideline for Labor for Brick Tile masonry What is brick tile work? What are the guidelines for labor for brickwork in superstructure? Don’t worry about all thes.. | | Guideline for Labor for Brick Work Foundation We all know the importance of brickwork in any construction, So the article here describes the guideline meant for la.. | | Purchasing Guidelines for Fine Aggregate/ Coarse Sand There should be no silt contents in Coarse Sand as the suppliers try to charge much amount by supplying the material o.. | | Guideline for Labor for Brick Work in Super Structure While going for construction, do we know the Guideline meant for Labor for Brick Work in Super Structure? If not then .. | | Buying tips for Bricks Before you buy bricks for home, office or any sort of construction follow these tips to ensure quality construction. | | Guideline for laying DPC Damp proof course or DPC is a major process in construction. There are several guideline meant for DPC which are desc.. | | Purchasing Guidelines for Marble and Granite Stone Marble stone should be hard, free from any stain i.e. deep cut or mark on the surface. | | What are various types of glasses used in doors? Types of glasses used in doors-Clear window glass, Plate glass, Prism glass, Quartz glass, Processed glass....... | | What are advantages and disadvantages of folding doors? Advantages of folding doors- Easy to install,washable, durable, superior sound damping. Disadvantages-sensitive to har.. | | What are various designs available in wooden doors? Designs available in Wooden doors..... | | What is standard size of internal folding doors? Size, Thickness and Weight of Internal Folding Doors....... | | What affects the life of doors? What can we do to increase the life of the Wooden doors? Tips to increase the life of Wooden doors.... | | What is the standard size of frame for Plastic/PVC doors? Plastic Door frame size carrying one or two shutters...... | | What are various frames recommended for Plastic/PVC doors? Frames for Plastic Doors.......... | | Which place is appropriate for sliding door? Appropriate places for sliding doors-Bathrooms, Backyards, Commercial structures........... | | What are various frames recommended for glass doors? Frames for Glass Doors-Wooden frames, Steel frames, Aluminium frames...... | | Which place is appropriate for folding doors? Appropriate places for folding doors-Homes, Offices, Guest rooms, gives attaractive and stylish look........ | | What are the various accessories recommended for folding doors? Accessories for folding doors- Door Handles, Door Fasteners,Door Viewers....... | | What affects the life of doors? What can we do to increase the life of the Plastic/PVC doors? Tips to increase the life of Plastic doors.... |
