Home -> Forums -> Construction -> Brick work -> Putty/Plastering breaking out
Sun Jul 22, 2012Total posts : 1
sam_m400
sam_m400
Topic: Putty/Plastering breaking out
In my rented house the black tint with putty/plastering is breaking out in main hall  where water is not there at all  . What could be the reason?
Sun Jul 22, 2012Post  #1
P. Panchal
P. Panchal
Remove all putty and redo it. Then paint again
8902
4637
time for paint and wall putty
2213
Painting interior walls
2524
541
2720
wall putty
Last answer on 1/2/2021 5:22:50 AM. by leelindsey. Forum started by paresh
3288
Wall Putty on exterior wall
2147
acrylic vs primer
Last answer on 1/21/2015 11:35:40 AM. by S L Gupta (Civil Engg). Forum started by paresh
1761
Cost of RCC ceiling plaster repair due to spalling
Last answer on 10/6/2014 12:46:05 PM. by S L Gupta (Civil Engg). Forum started by LM
1939
cost of RCC ceiling plaster repair due to spalling
Last answer on 10/7/2014 11:28:14 AM. by S L Gupta (Civil Engg). Forum started by LM
1104
Mere 1800 sq ft second flor house me plaster levling me nhi he. Contractor ne k
Last answer on 4/25/2018 1:05:26 AM. by S L Gupta (Civil Engg). Forum started by ILIYAS PATEL
3129
9909
4998
One putty mistry told that putty must be done before marble laying on floors as
Last answer on 7/4/2020 3:50:46 AM. by S L Gupta (Civil Engg). Forum started by Surinder Singh
2930
3383
Recurring Cracks
3850
2785
Plaster work
957
The roof slab is layed with clean shuttering plates and some places probably due
Last answer on 7/4/2020 3:34:29 AM. by Surinder Singh. Forum started by Surinder Singh
3674
wals
3268
compound wall
21928
3285
Bedroom Wardrobes information
2251
2217
1502
1974
1737
2231
2530
1507
1914
Brick or ACC block
2029
1663
2154
1711
4736
Brick wall on RCC slab
3938
2624
Checklist for Cement Plaster
Gypsum
Specification of ‘Plastering’
How to clean plaster ceiling?
Plastering
Plastering
What type of finishing is recommended for POP?
The plaster should be finished to a true and plumb surface.The plaster should be finished to a proper degree of smooth..
