QUANTITY MEASUREMENT
Tue Sep 13, 2016
Topic: QUANTITY MEASUREMENT
IF I WILL BUILT A RESIDENTIAL BUILDING OF 1000 SQ.FT.(GROUND FLOOR-FRAME STR.) , SO HOW TO CALCULATE REQUIRED BRICKS,SAND AND AGGREGATES? PLEASE GIVE ANY RATIO METHOD(LUM-SUM METHOD)
Tue Sep 13, 2016
Dear Mada
There is tool name estimator on the gharexpert.com website where you can calculate rough estimate quantity of all items.
2616
final bill
Last answer on 7/3/2020 10:03:19 PM. Forum started by
shuttering calucation
Last answer on 4/8/2014 1:21:34 PM. by
shaik khaja nayab rasool
20124
Last answer on 2/18/2022 6:35:57 PM. by
SusanBones
mani
6974
covered area rate includes chajjas measurement or not,includes door fixing or n
Last answer on 2/15/2022 10:53:23 PM. by
thiagogo
sudhir singh
3277
Last answer on 10/12/2014 9:03:20 PM. by
rajeev
2997
Last answer on 1/5/2022 12:45:53 AM. by
Last answer on 6/24/2013 9:59:46 PM. Forum started by
i Would like to know the measurements for width 27
Last answer on 10/3/2016 2:06:28 PM. by
Srinivas
2352
software
Last answer on 12/1/2021 6:05:00 PM. by
What are the normal fees for architect, civil engineering drawing, quantity surv
Last answer on 5/27/2013 11:48:46 AM. by
Vaibhav Jain
Anil Sood
please send the measurements so that iam grateful to you...and estimated cost bu
Last answer on 5/16/2012 10:44:00 PM. by
spmurmu
2676
Last answer on 10/12/2014 8:53:52 PM. by
nith_piyush
1408
Plan, measurements, back and side views of the house to be displayed.
Last answer on 6/21/2016 1:01:41 AM. by
Amrit Bhagat
ravikumar
1841
I would like to know the procedure to get the land measurement certificate(mojan
Last answer on 4/12/2016 2:49:57 PM. by
shashikantc
3258
Last answer on 7/30/2014 10:51:01 AM. by
Dhananjay
13755
Last answer on 1/26/2017 11:24:59 AM. by
Madhankumar
upendra
5176
RCC Lintel , cast and material esitmate
Last answer on 7/3/2020 10:47:13 PM. by
ndmalam
4201
Mohan Bhagwat
48110
Dimension Measurement of room
Last answer on 7/3/2020 9:06:19 PM. by
suresh
Kitan
