Home -> Forums -> Construction -> Foundation -> Query reqarding Foundation & Tie Beam
Tue Jan 06, 2015Total posts : 2
Gian Prakash
Gian Prakash
Topic: Query reqarding Foundation & Tie Beam
I'm planning to construct a new house. For which, I have few questions regarding Tie Beam (Concrete column used to connect columns in foundation).
What should be the height/location of Tie beam... at plinth level ?? (and if its at plinth level then what should be underneath of tie beam to support it.. Soil/ Bricks and whether Brick work & DPC is required in this case for dampness prevention) or below ground level ?? (and if its below ground level then whether Brick work & DPC is required. If not, than how dampness will be prevented).
Fri Jan 09, 2015Post  #1
The architect can design the same for you in a better manner. The installation has to be done by a good Civil Engineer.
Sat Jan 10, 2015Post  #2
Dear Gian
      There are two ways one is to lay tie beam at plinth level, in this case the outer wall are taken 1feet deep from ground up to the bottom of beam, internal walls not need the wall. Second is to lay tie beam at ground and lay DPC at plinth level.
4800
tie beam obsolete
2422
2824
9197
2583
Re. eccentric footing.
Last answer on 12/6/2013 12:11:41 PM. by S L Gupta (Civil Engg). Forum started by vignesh_mp
65240
3884
stone foundation
10048
9042
Absence of Plinth Beam
Last answer on 7/3/2020 9:29:19 PM. by Pritam Thakur. Forum started by Pritam Thakur
1640
sir i have a query how can i contract
Last answer on 1/10/2016 8:48:39 PM. by JAI PRAKASH. Forum started by VINAY
2572
sir i have a query how can i contract my email id is vsp106@gmail.com
Last answer on 10/11/2021 4:59:19 AM. by JAI PRAKASH. Forum started by VINAY
1798
RCC foundation instead of brick foundation
Last answer on 9/23/2015 8:37:51 AM. by gpeter. Forum started by gpeter
1790
like an answer to my query as it is important.drsingh
Last answer on 9/5/2010 11:55:20 PM. by Gunjan Utraja. Forum started by dr singh
5663
Column and beams specification for 5-7 floor house
Last answer on 8/7/2011 5:52:06 PM. by timm todd. Forum started by timm todd
4665
Regarding Beam
13857
Pillar & plinth beam frame work avoiding stone foundation
Last answer on 5/11/2017 11:22:09 AM. by S L Gupta (Civil Engg). Forum started by tp_bangalore
1890
1065
1657
2684
Pillar
2140
Curing urgent
2372
structure work
5166
Pillar foundation
2204
new house
2821
building a house
1992
Construction Agreement
3091
Foundation
2272
Foundation
1477
10048
3660
Foundation
2115
Structure proof checking
2558
Foundation design
2462
2468
Saria and cement
3657
Wall Thickness
2679
3180
13268
Steel Type
Designing
Designing a Foundation
Centering
Dining
Dining Room Ceiling
