Home -> Forums -> Construction -> Brick Walls, Pillars and Structure -> RAT-TRAP BOND TECHNOLOGY
Tue Oct 11, 2011Total posts : 3
ani
ani
Topic: RAT-TRAP BOND TECHNOLOGY
HI! MY POOJA GREETINGS TO ALL.
This is an excellent site for sharing opinion my dream house with the experts including the viewers of this site.
My question: 1)  What is RAT-TRAP BOND TECHNOLOGY ?
                    2) Dose it really reduce the cost of house construction  and is it better than traditional technology ?
                    3) Is it effective for 3 storied house construction in the climatic condition of SOUTH KOLKATA (West Bengal) ?
                    4) If the so called technology be applied in building construction, can it be cause of headache regarding the strength of the building ?
 And lastly,   5) Is there be any specially trained labours required for this technology ?
                    Please provide the Pros and Cons regarding this RTB Technology so that I can proceed accordingly.
                    With regards to all...................   ANIRBAN
Fri Oct 14, 2011Post  #1
Rat-trap bond, also known as Chinese bond, is a type of garden wall bond similar to Flemish, but consisting of rowlocks and shiners instead of headers and stretchers (the stretchers and headers are laid on their sides, with the bed face of the stretcher facing outward). This gives a wall with an internal cavity bridged by the headers, hence the name. The main advantage of this bond is economy in use of bricks, giving a wall of one-brick thickness with fewer bricks than a solid bond.
But in my opinion use engish bond for strength.
Tue Oct 18, 2011Post  #2
amit
amit
Post subject: fly ash brick
dear sir,
pl enlighten me on use of flyash brick and its availability and cost effectiveness. is it cheap than normal bricks. i want to use this for my house on 2nd floor construction. the durabilty can also be informed, thanks
Tue Oct 25, 2011Post  #3
Dear amit
Fly ash bricks are generally used for making curtain and partition walls of the houses/ buildings. Fly ash bricks are used in domestic building in the category of low or middle-income groups mostly have single or two storied dwelling units. Use of fly ash bricks in this type of construction is meant mainly to achieve economy and make profits.
PWD-DELHI Issues Circular for Use of Fly ash Brick
“The PWD-DELHI department Suggested Experimental Use of Fly ash bricks in Site office, Temporary Accommodation/ Boundary walls”
1510
Electrical wiring
Last answer on 11/1/2015 6:41:12 PM. by JAI PRAKASH. Forum started by ani
2403
1357
Really an informative article on rat trap bond.helping me a lot.just to ask that
Last answer on 12/30/2016 12:59:53 PM. by S L Gupta (Civil Engg). Forum started by sabrina
3234
Ferrocement channels roofing Vs Rcc slab
Last answer on 9/15/2021 9:04:11 PM. by S L Gupta (Civil Engg). Forum started by Sameer S Pawade
8962
are keeping rats good for vastu in house
Last answer on 8/20/2012 11:04:19 AM. by Amit Hasija. Forum started by aditya
1944
RATS PRESANTS IN SHOWROOM GOOD YA BAD
Last answer on 1/17/2012 6:21:32 PM. Forum started by KAPIL
2818
Last answer on 2/13/2012 3:19:03 PM. by PR Jawahar. Forum started by pallubc2
1777
How I can buy this s trap
Last answer on 6/8/2013 6:14:17 PM. by Navneet Jharia. Forum started by joemon
1798
what is the diffrence between s-trap and p-trape
Last answer on 7/29/2014 2:29:59 PM. by S L Gupta (Civil Engg). Forum started by SANJAY DUSANE
1725
WHICH TRAP IS USED FOR INDIAN AND EUROPIAN W.C.
Last answer on 7/30/2014 9:21:40 PM. by Purvi Panchal. Forum started by SANJAY DUSANE
1110
Fresh cut bank instrument for lease/sale, such as BG,SBLC, MTN, Bank Bonds,speci
Last answer on 1/7/2021 2:27:50 AM. Forum started by marga
1790
pl.send latest archi.view of building and latest technology of indiestries.Thank
Last answer on 11/15/2011 5:31:00 PM. by Amit Hasija. Forum started by prakash gohel
2018
what traps should be used for wash basins and kitchen sinks, enclosed or open?
Last answer on 3/3/2014 12:22:33 PM. by S L Gupta (Civil Engg). Forum started by neelam rathi
1594
do bottle traps get clogged easily and are they easy to clean?
Last answer on 7/18/2014 12:10:12 PM. by seema tyagi. Forum started by neelam rathi
5097
Stop Rats from entering In house via Drain pipe
Last answer on 6/10/2011 11:47:24 PM. by P. Panchal. Forum started by P. Panchal
9087
Bathroom with no sunken slab
Last answer on 7/3/2020 9:35:17 PM. by rinondavid. Forum started by Swaroop
2349
Traps - Types and Uses
Last answer on 7/3/2011 1:35:26 AM. by S L Gupta (Civil Engg). Forum started by SHAMS
2682
commode type and flush type
New Construction Technology
Last answer on 11/21/2013 1:48:17 AM. Forum started by Tayib
5810
3792
9883
2670
4143
2865
5006
3655
1864
2799
2609
2372
2462
2638
1807
3607
6253
Brick Bonds
Do you know good brick bonds can ensure the strength of a building? Only you need to select appropriate bond for walls..
Traps
Proper drainage system is essential for waste water of the house. Traps and water seal are an important part of draina..
Compact
Compact Hi-Tech Kitchen
Importance
