WHAT IS THE RATIO
Fri Dec 17, 2010Total posts : 2
S.BHUPAL RAJU
S.BHUPAL RAJU
Topic: WHAT IS THE RATIO
    1. WHAT IS THE CORRECT RATIO TO BE MIXED FOR RCC ROOF. CEMENT SAND CLINKER ETC TO BE MIXED FOR FIRST FLOOR
Sat Dec 18, 2010Post  #1
The ratio of RCC should be either 1:2:4 i.e 1 part of cement, 2 parts of coarse sand and 4 parts of bazri/ stone aggrigate 20 mm, or 1:1.5:3 i.e1 part of cement, 1.5 parts of coarse sand and 3 parts of bazri/ stone aggrigate 20 mm.For more information  you should visit construction section of gharexpert.com website in the cement concrete section where you will find much more about RCC beam and slab.
Sat Dec 18, 2010Post  #2
santosh kumar
santosh kumar
Post subject: RCC ratio for floor slab and beam
The ratio of R.C.C should be 1:1.5:3 i.e cement :sand:Aggregate
2415
roof concrete
2413
3575
construction current rate
1565
What's are ratio of m25
Last answer on 1/5/2022 12:37:11 AM. by S L Gupta (Civil Engg). Forum started by R.k banshal
3792
2184
3415
SOR
Last answer on 12/30/2021 10:26:27 AM. by S L Gupta (Civil Engg). Forum started by navneet
2064
cement : sand:stone ratio
2677
1767
1460
1525
MIX PROPORTION
Last answer on 5/13/2016 10:51:18 AM. by S L Gupta (Civil Engg). Forum started by ANKITA MADA
1718
CONCRETE MIX
Last answer on 7/3/2020 9:36:11 PM. by M Prabhu. Forum started by M Prabhu
1451
Is the concrete mix ratio M20 (1:1.5:3) weight based? If yes, whether volume based 1:2:4 ratio is almost equal to M20?
Last answer on 3/10/2017 12:37:18 PM. by S L Gupta (Civil Engg). Forum started by vinu
2466
1869
Can anyone suggest the breakup ratio percentage cost like up to plinth beam, up
Last answer on 1/2/2021 5:27:29 AM. by S L Gupta (Civil Engg). Forum started by Shaik ibrahim
1079
I am about to construct my house..Would like to know that the plan I am sending
Last answer on 7/4/2020 2:46:48 AM. Forum started by SSHILPI
2372
i am civil engineerimg student iam in my last yeari am preparing my final year p
Last answer on 10/12/2021 10:36:28 PM. by S L Gupta (Civil Engg). Forum started by sultan
15
17
Concrete Mix Ratio
Designing
Designing a Foundation
Cement
Cement Concrete
