Home -> Forums -> Construction -> Ground work -> RCC Column
RCC Column
Mon Nov 12, 2012Total posts : 3
Swarup
Swarup
Topic: RCC Column
Rcc Column construction (250x300 with 6-12dia. rod) for 2storied residentiial building (around 85sq.ft.) was done as advised by one of my friend.
Now I am worried that weather it is safe or not? if not please suggest the remedy. only ground floor superstructure has been construted. I will start construction of 1st floor by mid december. any safety measure needs to be taken during construction of 1st floor.
Please advise.
Mon Nov 12, 2012Post  #1
Dear Swarup
           The provision of MS Steel rod nos and dia for making RCC columns are depend upon the load coming on the column, span of the column. From your question it is not clear what length of span is. In my view you should contact any civil engineer or structural engineer who can give you suggestion after visiting your home.
Mon Oct 21, 2013Post  #2
carol
carol
Post subject: rcc columns
we are putting rcc columns for our building. Here, we get ground water at 5.5 ft. But, structural engineer wants the trench depth to be 8 ft.
So, what precautions should we take and how should we remove so much water. What is the procedure for this. Please explain.
Tue Oct 22, 2013Post  #3
Dear Carol
      Please contact your structural engineer from whom you have taken design of columns, who will give you the remedy  acccording to his design.
2719
2539
3013
9885
3571
R.C.C. column in Sqft
2382
RCC Columns- Ditrection
Last answer on 7/20/2011 3:25:23 PM. by S L Gupta (Civil Engg). Forum started by Jairaj Kamthan
2600
RCC Column Construction
Last answer on 3/3/2014 11:50:44 AM. by S L Gupta (Civil Engg). Forum started by Anuj Prakash
4367
RCC Columns
2537
RCC column (pillar)
3623
2159
Brick workmanship supervision
Last answer on 5/27/2013 11:28:55 AM. by S L Gupta (Civil Engg). Forum started by arctushar
4799
tie beam obsolete
4646
What is the RCC column size for 20 feet distance for two floor house.These 20 fe
Last answer on 2/23/2014 8:38:52 PM. by Navneet Jharia. Forum started by somvir
1916
traditional house construction
Last answer on 2/24/2014 6:28:15 PM. by Shanthakumar. Forum started by vikram
2626
How to hide Rain water pipe
1315
we want to replace or modify our existing AC sheet roof, also we want to do POP
Last answer on 3/5/2016 9:24:10 PM. by JAI PRAKASH. Forum started by bipin karekar
1273
Replacement or modification Of AC ROOF
Last answer on 3/5/2016 9:23:56 PM. by JAI PRAKASH. Forum started by bipin karekar
2995
8159
software
3899
2730
1833
lanterns
3133
false ceiling
2245
about construction
1786
4153
Cement Coba
3076
Water Harvesting System
1676
1758
water tank
2058
1760
1634
Pool construction cost
1994
2738
Regarding roof beam
Fire Stair case
2645
2371
super structure
Type
How To Repair Cracks
