Home -> Forums -> Construction -> Steel -> RCC Columns
RCC Columns
Tue Dec 24, 2013Total posts : 4
Ilias Ahmed
Ilias Ahmed
Topic: RCC Columns
I have a vacant land for 1420 Sq.ft, As of now I am planning to build Only ground floor but later I will build up to Second floor.
Can anyone let me know what should be the coumn size and gauge for TMT Steel rods.
I have attached ground floorPlan for your review
Attachments: Ground Floor .png on Tue Dec 24, 2013,&n
Wed Dec 25, 2013Post  #1
Dear Ahmed
        It is better if you take structural design from any structure engineer.For youe query I am in view that keep the column size 9''x9'' and use 6 nos 16 mm dia steel bars.
Mon Jan 06, 2014Post  #2
Ahmed
Ahmed
Tks Mr.Gupta
My Engineer is telling me to go for 9" x 9" with 4 Nos of 12 MM TMt steel rods as it is sufficinet for g+2 otherwise column will crack in 6 months.
I need your advice.
Mon Jan 06, 2014Post  #3
Dear Pattyman
           Your engineer may be right.But Keeping safety factor in mind i.e. there are earth quack and storm etc and keep the building earth quack proof. Secondly when you are given load of wall and slab to beam which was bear by the column, by that column should be strong.Give proper cover to the steel bars at least 1'' and proper mix of cement concrete be used and do proper curing, there should  not be any problem like crack.
Mon Jan 06, 2014Post  #4
Ahmed
Ahmed
Tks again Mr. Gupta, that' was useful, the RCC ratio is 1:1.5:3
2719
2539
3013
9885
4052
RCC Column
Last answer on 10/22/2013 4:25:37 PM. by S L Gupta (Civil Engg). Forum started by Swarup
3571
R.C.C. column in Sqft
2382
RCC Columns- Ditrection
Last answer on 7/20/2011 3:25:23 PM. by S L Gupta (Civil Engg). Forum started by Jairaj Kamthan
2600
RCC Column Construction
Last answer on 3/3/2014 11:50:44 AM. by S L Gupta (Civil Engg). Forum started by Anuj Prakash
2537
RCC column (pillar)
3623
2159
Brick workmanship supervision
Last answer on 5/27/2013 11:28:55 AM. by S L Gupta (Civil Engg). Forum started by arctushar
4799
tie beam obsolete
4646
What is the RCC column size for 20 feet distance for two floor house.These 20 fe
Last answer on 2/23/2014 8:38:52 PM. by Navneet Jharia. Forum started by somvir
1916
traditional house construction
Last answer on 2/24/2014 6:28:15 PM. by Shanthakumar. Forum started by vikram
2626
How to hide Rain water pipe
1315
we want to replace or modify our existing AC sheet roof, also we want to do POP
Last answer on 3/5/2016 9:24:10 PM. by JAI PRAKASH. Forum started by bipin karekar
1273
Replacement or modification Of AC ROOF
Last answer on 3/5/2016 9:23:56 PM. by JAI PRAKASH. Forum started by bipin karekar
2684
steel requirment
15582
1992
Residential complex
3238
7479
Bar Bending Schedule Software
2521
steel
29942
2613
9362
2260
Current iron rod price
2606
1885
Steel Erectors
2382
3266
13772
overlap length to steel
2160
2539
Type
How To Repair Cracks
