Home -> Forums -> Construction -> Start Construction -> RCC Columns- Ditrection
Wed Jul 20, 2011Total posts : 1
Jairaj Kamthan
Jairaj Kamthan
Topic: RCC Columns- Ditrection
Need help in deciding about the direction of rectangular column.Is it essential, technically, to place the lenth in the direction of the span of room or it doesn't matter?
Thu Jul 21, 2011Post  #1
Dear Jairaj
        It is not hard and fast rule that the length be placed in the direction of the span. If  it is done it will reduce the length of the span but some time due to thickness of wall or other architectural feature we have to adjust the size of column accordingly.
2719
9885
3941
2539
3013
2537
RCC column (pillar)
3623
2602
RCC Column Construction
Last answer on 3/3/2014 11:50:44 AM. by S L Gupta (Civil Engg). Forum started by Anuj Prakash
4370
RCC Columns
3571
R.C.C. column in Sqft
4052
RCC Column
Last answer on 10/22/2013 4:25:37 PM. by S L Gupta (Civil Engg). Forum started by Swarup
2159
Brick workmanship supervision
Last answer on 5/27/2013 11:28:55 AM. by S L Gupta (Civil Engg). Forum started by arctushar
4799
tie beam obsolete
2298
RCC Framed Structure: Sequence of constructioin
Last answer on 12/27/2014 3:22:06 PM. by S L Gupta (Civil Engg). Forum started by Arvind Bhaskar
4647
What is the RCC column size for 20 feet distance for two floor house.These 20 fe
Last answer on 2/23/2014 8:38:52 PM. by Navneet Jharia. Forum started by somvir
2219
COST OF COLUMN PER SFT
Last answer on 5/24/2021 11:15:40 PM. by JAI PRAKASH. Forum started by Ganesh
3311
2312
Type
How To Repair Cracks
