Home -> Forums -> Construction -> Brick Walls, Pillars and Structure -> RCC Framed Structure: Sequence of constructioin
Sat Dec 27, 2014Total posts : 1
Arvind Bhaskar
Arvind Bhaskar
Topic: RCC Framed Structure: Sequence of constructioin
I am building a house using RCC framed structure where the load of roof will be on beams and columns and not on walls. What should be the sequence of construction..
Columns, Ceiling and Walls
Or Columns , Walls and then Ceiling.
Sat Dec 27, 2014Post  #1
Dear Bhaskar
                 It makes no difference to take any sequence. If building is multy story than use first option for speedy work for next story.
1746
2210
2190
Size of the Roof Level Beam in RCC framed structure
Last answer on 1/30/2015 12:12:31 PM. by S L Gupta (Civil Engg). Forum started by Arvind Bhaskar
8848
Last answer on 10/15/2014 1:52:38 PM. by SANJAY DUSANE. Forum started by Ambuj
2256
14595
5856
2665
sir i want to know that what would be the cost total consturction of 2200 sq.ft
Last answer on 2/15/2022 11:12:49 PM. by JAI PRAKASH. Forum started by shruti Adarsh
2524
1943
Cost of Steel construction
3655
5226
2731
3002
House Estimation Breakdown
3090
Last answer on 7/26/2009 8:35:08 PM. by Ganesh. Forum started by cosntruction novice
4039
Cost Comparison Between Brick Wall & Concrete Frame Structure
Last answer on 7/3/2020 11:40:50 PM. by PR Jawahar. Forum started by PR Jawahar
2722
Cost of RCC
Last answer on 4/4/2014 2:22:58 PM. by S L Gupta (Civil Engg). Forum started by Vasanth
2330
5223
5811
3792
9884
2670
4627
4143
2865
5006
3655
1864
2800
2610
2372
2462
2638
1807
3608
6254
Door
Door and Window Frames
Earthquake
