Sat Jan 11, 2014 | Total posts : 2 |
| Topic: RCC Lintel , cast and material esitmate
dears, I want to get estimate of material quantity for my home second floor lente. total covered area is 1400 sq ft . 5 inch thick lintel is proposed. i want to get estimate of quantity. cement steel bar. best regards.
Sun Jan 12, 2014 | Post #1 | Navneet Jharia
Join date: Dec 2010 | Post subject: RCC Slab, cast and material esitmate
Dear ndmalam. Hello.. I think you want to know about Roof slab of second floor, for 5" thick ,1400 Sq.Ft. area ,the required materials for Concrete at ratio 1:2:4, Cement 120 bags , Sand (fine aggregate) 450 cuft. Coarse aggregate (Gitty) 1/2"+3/4" 600 cuft. Steel Bars._ Steel should be as per Steel design of Roof Slab,and calculated for slab ,Balconies and Beams, the sizes of steel bars depends on span of slab and beams. approximately for slab only it will be about 1600 kg. Kindly get steel design as per plan with local Structural Engineer and save material and money... regards | |
Questions (39) | |
1702 views | 1 answers | Last answer on 8/24/2016 12:11:54 PM. by S L Gupta (Civil Engg). Forum started by vinu | 4128 views | 1 answers | Last answer on 1/6/2022 11:48:27 PM. by S L Gupta (Civil Engg). Forum started by vinu | 2301 views | 4 answers | Last answer on 10/26/2015 11:20:10 AM. by S L Gupta (Civil Engg). Forum started by Vinod |
| 7232 views | 3 answers | Last answer on 5/17/2016 1:30:52 PM. by S L Gupta (Civil Engg). Forum started by Shardul | 2421 views | 2 answers | Last answer on 8/20/2015 2:23:19 AM. by JAI PRAKASH. Forum started by Gunjan | 1817 views | 3 answers | Last answer on 4/8/2015 11:12:40 PM. by JAI PRAKASH. Forum started by Yashodhara Ray Chaudhuri | 1751 views | 3 answers | Last answer on 12/11/2020 12:20:05 PM. by JAI PRAKASH. Forum started by PRAVEENKUMAR | 1908 views | 1 answers | Last answer on 11/19/2020 4:21:26 AM. by S L Gupta (Civil Engg). Forum started by Sanzana Hosen | 17 views | 0 answers | Last answer on 12/14/2024 1:34:53 AM. Forum started by rupeshji | 17 views | 0 answers | Last answer on 12/14/2024 1:51:46 AM. Forum started by rupeshji | 16 views | 0 answers | Last answer on 12/14/2024 1:57:32 AM. Forum started by rupeshji | 15 views | 0 answers | Last answer on 12/14/2024 11:26:13 PM. Forum started by rupeshji | 18 views | 0 answers | Last answer on 12/14/2024 11:32:23 PM. Forum started by rupeshji | 20 views | 0 answers | Last answer on 12/14/2024 11:34:52 PM. Forum started by rupeshji | 9 views | 0 answers | Last answer on 12/17/2024 12:42:30 AM. Forum started by rupeshji | 10 views | 0 answers | Last answer on 12/17/2024 12:44:48 AM. Forum started by rupeshji | 18 views | 0 answers | Last answer on 12/17/2024 12:49:43 AM. Forum started by rupeshji | 10 views | 0 answers | Last answer on 12/18/2024 10:25:26 PM. Forum started by rupeshji | 11 views | 0 answers | Last answer on 12/18/2024 10:29:20 PM. Forum started by rupeshji | 10 views | 0 answers | Last answer on 12/21/2024 12:29:49 AM. Forum started by rupeshji | 7 views | 0 answers | Last answer on 12/21/2024 12:29:40 AM. Forum started by rupeshji | 6 views | 0 answers | Last answer on 12/21/2024 12:29:32 AM. Forum started by rupeshji | 5 views | 0 answers | Last answer on 12/21/2024 12:29:24 AM. Forum started by rupeshji | 6 views | 0 answers | Last answer on 12/21/2024 12:29:18 AM. Forum started by rupeshji | 7 views | 0 answers | Last answer on 12/21/2024 12:29:12 AM. Forum started by rupeshji | 4 views | 0 answers | Last answer on 12/21/2024 12:29:05 AM. Forum started by rupeshji | 5 views | 0 answers | Last answer on 12/21/2024 12:28:58 AM. Forum started by rupeshji | 4 views | 0 answers | Last answer on 12/21/2024 12:28:51 AM. Forum started by rupeshji | 6 views | 0 answers | Last answer on 12/21/2024 12:28:44 AM. Forum started by rupeshji | 3 views | 0 answers | Last answer on 12/21/2024 12:28:38 AM. Forum started by rupeshji | 6 views | 0 answers | Last answer on 12/21/2024 12:28:31 AM. Forum started by rupeshji | 7 views | 0 answers | Last answer on 12/21/2024 12:28:24 AM. Forum started by rupeshji | 8 views | 0 answers | Last answer on 12/21/2024 12:28:18 AM. Forum started by rupeshji | 9 views | 0 answers | Last answer on 12/21/2024 12:28:10 AM. Forum started by rupeshji | 7 views | 0 answers | Last answer on 12/21/2024 12:28:03 AM. Forum started by rupeshji | 5 views | 0 answers | Last answer on 12/21/2024 12:27:56 AM. Forum started by rupeshji | 3 views | 0 answers | Last answer on 12/21/2024 12:27:22 AM. Forum started by rupeshji | 4 views | 0 answers | Last answer on 12/21/2024 12:27:16 AM. Forum started by rupeshji | 6 views | 0 answers | Last answer on 12/21/2024 12:27:08 AM. Forum started by rupeshji |
Articles that might interest you! | | RCC Roofing This roofing is very versatile and provides great protection. | | Tips for Laying RCC slab / roof RCC slab laying is one of major step in any type of construction so it is mandatory to know all the points related to .. | | Labor Guideline for Steel bars in RCC Every process needs proper guideline and expert person or team to manage in construction or in any field. Even working.. | | Types of arch Types of Arches:
Segmental arch ( Syrian arch) : An arch which is not whole semicircular and not flat. You can use th | | Purchasing Guidelines for Sanitary material and Precautions While Laying Sewer Pipes line Cast iron pipe is generally used in sewer lines. The points should be kept in view while purchasing CI pipes. | | Glass window finishing materials For glass window, verity of finishing martial available in the market. Here is a complete description of all the finis.. | | Cracks at the junctions of Brick Walls and RCC slabs Handle the cracks in the walls initially because they can destroy smooth finishing of the plaster. | | Type of Steel Bars Different steel bars are recommended for their relative tensile stresses.Steel bars are major components of constructi.. | | Mild Steel Bars in Cement Concrete Mild steel bars in reinforced concrete are one of the exceptional building materials. Reinforced concrete requires ver.. | | Water Storage Solution Storage of water in proper way is essential for drinking, cleaning, bathing, cooking purposes in our day-to-day life. .. | | What are various types of glasses used in doors? Types of glasses used in doors-Clear window glass, Plate glass, Prism glass, Quartz glass, Processed glass....... | | What are advantages and disadvantages of folding doors? Advantages of folding doors- Easy to install,washable, durable, superior sound damping. Disadvantages-sensitive to har.. | | What are various designs available in wooden doors? Designs available in Wooden doors..... | | What is standard size of internal folding doors? Size, Thickness and Weight of Internal Folding Doors....... | | What affects the life of doors? What can we do to increase the life of the Wooden doors? Tips to increase the life of Wooden doors.... | | What is the standard size of frame for Plastic/PVC doors? Plastic Door frame size carrying one or two shutters...... | | What are various frames recommended for Plastic/PVC doors? Frames for Plastic Doors.......... | | Which place is appropriate for sliding door? Appropriate places for sliding doors-Bathrooms, Backyards, Commercial structures........... | | What are various frames recommended for glass doors? Frames for Glass Doors-Wooden frames, Steel frames, Aluminium frames...... | | Which place is appropriate for folding doors? Appropriate places for folding doors-Homes, Offices, Guest rooms, gives attaractive and stylish look........ | | What are the various accessories recommended for folding doors? Accessories for folding doors- Door Handles, Door Fasteners,Door Viewers....... | | What affects the life of doors? What can we do to increase the life of the Plastic/PVC doors? Tips to increase the life of Plastic doors.... |
