RCC Roof SPAN
Sat May 18, 2013Total posts : 3
Rajesh
Rajesh
Topic: RCC Roof SPAN
Hi-
I am constructing my 2nd floor and need some advise.
The total area for the RCC roof is approx. 1000 sq. feet.
It's a big almost square hall with 30' x 32' with a 9 inch wall almost in the middle but it is only extending upto 14 feet of the whole hall length of 32 feet.
What's the best method for casting a RCC roof and how many cantilever beams I will need?
Thanx
Rajesh
Mon May 20, 2013Post  #1
Dear Rajesh
   It is the design matter and can be given after the study of drawing of the house for which it is to be constructed.
Wed May 29, 2013Post  #2
Rajesh
Rajesh
Dear Mr. Gupta-
I've started the shuttering to cast the RCC slabs now using steel plates and channels.
What's the best cantilever angle/slope for a slab 32 feet x 13 feet room with a height of 9 feet?
Rajesh
Wed May 29, 2013Post  #3
Dear Rajesh
  • While doing shuttering of a cantilever part, outer edge of shuttering is 1” to 2'' higher than inner edge with the wall.
  • The bracing of vertical supports for cantilever portion should be tied to vertical supports of internal slab.
  • The concrete should be laid on cantilever portion very gently.
  • The shuttering should be removed after 28 days.
  •  For more detail about shuttering see the link below.
  • http://www.gharexpert.com/articles/Cement-Concrete-1753/Centering-Shuttering--Form-Work_0.aspx
Roof Beam
1764
3753
6380
kota Stone Roofing
3802
9893
2991
3980
Roof leakage
2054
4647
1875
4953
2126
1846
SLAB LOADING
Last answer on 12/24/2015 4:05:10 AM. by JAI PRAKASH. Forum started by ANISH
2255
Hello members..i am building a small bungalow in Karjat .Mumbai.. and would like
Last answer on 1/27/2015 7:22:56 PM. by JAI PRAKASH. Forum started by FRANCO VAZ
13755
2539
Cooper
