RCC Roof
Thu May 07, 2015Total posts : 2
ARVIND GOYAL
ARVIND GOYAL
Topic: RCC Roof
Sir
 Which one is better in RCC Roof
kamdhenu steel bars or Jindal steel bars
Thu May 07, 2015Post  #1
Dear Arvind
           Both Steel bars are equally good for use in RCC if you want to go in deep than take the sample of both steel and take the result of lab. Some of test is given below.
Physical Requirement:
 S.No Types of nominal size of bars   Ultimate Tensile Stress N/mm2 minimum  Yield Stress N/mm2  Elongation Percent minimum
 1. Mild Steel Grade I or Grade 60
   For bars up to 20mm  410 250  23
   For bars above 20mm upto 50 mm  410 240  23
 2.  Mild Steel Grade-II or Grade 40
   For bar up to 20mm  370 225 23
   For bars above 20mm upto 50 mm  370 215  23
 3. Medium Tensile Steel Grade-75
   for bars up to 16mm  540 350 20
   for bars above 16 mm up to 32 mm    540 340  20
   for bars above 32 mm up to 50 mm  510 330  20
Grade II Mild steel bar are not recommended for use in structures located in earth quake zones subject to severe damage and for structures subject to dynamic loading (other than wind loading) such as railways and highways bridges.
Every lot or consignment of mild steel bars brought at the site of work should be tested in laboratory before use in the work. However for small work one can use mild steel bars on the basis of verifying tests results made by manufacturer in his own laboratory; which are available with supplier.
Some of manufacturers stamped MS bars grade with their make /name and also give certification of test and grade. On the basis of the above information you can store mild steel bars grade-wise at the site of work.
Tue May 12, 2015Post  #2
All bars have 2 qualities made of scrap or fresh, Both have different price range and life span.
Questions (40)
9893
6381
kota Stone Roofing
3754
2054
2613
Last answer on 5/26/2016 10:55:05 AM. by S L Gupta (Civil Engg). Forum started by Madhu Ranjan
2033
6412
RCC Roofing Cost
Last answer on 12/11/2013 11:01:19 AM. by S L Gupta (Civil Engg). Forum started by Praveen Srivastava
2616
Exterior Walls
13756
4402
I would like to know How much Minimum maintain the re inforcment spacing in the
Last answer on 12/31/2020 2:22:36 AM. by Girish. Forum started by tkalaiva
4365
WHAT IS THE RATIO
191901
25609
CURING TIME FOR RCC ROOF
2260
advise
Last answer on 8/16/2013 1:07:43 PM. by S L Gupta (Civil Engg). Forum started by faroque
3087
3348
4431
1480
19155
Last answer on 7/3/2020 10:47:35 PM. by S L Gupta (Civil Engg). Forum started by Techman
24767
15
17
ACC
ACC Sheet Roofing
Cooper
