Home -> Forums -> Construction -> Start Construction -> RCC SLAB
RCC SLAB
Mon Dec 23, 2013Total posts : 1
nagendrabk
nagendrabk
Topic: RCC SLAB
Hello
Can i constuct a RCC slab on brick walls , if i am not planning to construct column during construction. What will be the impact of same? Will there be any cost difference for brick walls vs colums?
nagendra
Mon Dec 23, 2013Post  #1
Dear Nagendra
        You can lay R CC slab on walls if walls are load bearing and  wall thicness should not be less than  9'' thick.
Do not place slab on  4.5'' walls.
2294
Last answer on 6/16/2021 11:37:22 AM. by S L Gupta (Civil Engg). Forum started by dnyanesh
2407
5862
1460
4836
3966
cost estimater
3784
difference b/w colum, beam and RCC slab
Last answer on 7/25/2013 5:09:29 PM. by LAKWINDER. Forum started by paresh
3980
Roof leakage
1981
Last answer on 10/27/2015 10:43:31 PM. by JAI PRAKASH. Forum started by Baba Dedge
2657
Roof Design options
Last answer on 9/11/2020 5:52:32 AM. by leelindsey. Forum started by richlyn
2450
I intend to put non skid tiles at bath (Sunken Slab) at first floor. Please conf
Last answer on 1/23/2013 1:14:36 PM. by S L Gupta (Civil Engg). Forum started by shahidain
2878
Last answer on 9/30/2020 7:45:37 AM. by Vijay Mishra. Forum started by SCK
3085
cost of rcc roof
Last answer on 12/27/2013 11:59:27 AM. by S L Gupta (Civil Engg). Forum started by abdul wahid laskar
1598
Last answer on 1/5/2022 8:30:54 PM. by S L Gupta (Civil Engg). Forum started by Pranav
4953
2842
Water seepage from RCC slab
4241
mix design of rcc slab
Last answer on 7/31/2012 11:18:03 AM. by S L Gupta (Civil Engg). Forum started by ranvir kumar singh
3199
Labour Cost for RCC slab
Last answer on 11/9/2012 8:06:29 PM. Forum started by Gilbert
3312
2236
2312
2061
Iron
Iron Sheet Roofing
Type
