Home -> Forums -> Construction -> Layout and House Plans -> RCC design
RCC design
Fri Jan 30, 2015Total posts : 1
minhaj sk
minhaj sk
Topic: RCC design
i am currently studying civil engineering , 3rd year.i would like to ask whether whatever we learn in RCC design like two way shear design ,one way shear design,column design, is it practically needed to design a building, or there is any other method of designing a roof,stairs,columns??
Sat Jan 31, 2015Post  #1
Post subject: RCC design in 3rd yr. civil engineering
Hello..! Minhal, Yes ,RCC design of various structures are used practically in the field, from small residential buildings to multi storied  apartments. Also used  to design large bridges,dams, High ways, irrigation structures  etc. It is the base of CIVIL Engineering..so you can design any type of structure depending upon its need...So don't be confused ,there is no short cut method..Study hard...All the best.....
2054
1702
3160
Last answer on 7/31/2020 7:39:42 AM. Forum started by Prahbjot Singh
4241
mix design of rcc slab
Last answer on 7/31/2012 11:18:03 AM. by S L Gupta (Civil Engg). Forum started by ranvir kumar singh
1473
3328
Design of RCC Pergola Beams
Last answer on 6/16/2015 4:18:19 AM. by JAI PRAKASH. Forum started by Tony
4028
Last answer on 6/16/2015 4:18:15 AM. by JAI PRAKASH. Forum started by Tony
2599
Last answer on 6/16/2015 4:18:07 AM. by JAI PRAKASH. Forum started by Tony
6381
kota Stone Roofing
2407
2898
RCC Roof
2131
what are requirements of RCC cantilever length?
Last answer on 12/24/2014 11:46:06 AM. by S L Gupta (Civil Engg). Forum started by syed basha
4232
labour rate
13786
rcc rate per cubic meter
Last answer on 10/20/2014 12:03:29 PM. by S L Gupta (Civil Engg). Forum started by anks
3753
2807
35211
2691
2924
2188
2184
2791
4520
1890
2284
2265
2766
3464
2356
1967
2242
3595
2324
2090
2792
1548
2114
Type
Porch
Porch Designs
Ceiling
