Foundation
RCC foundation instead of brick foundation
Sat Sep 19, 2015
gpeter
Topic: RCC foundation instead of brick foundation
Hi Friends,
I want to build a 2nd garage. The current garage has a brick foundation
75cm deep
below ground level. It is a step foundation almost as given in GharExpert for(9" thick brick wall load bearing foundation).
The garage has a single brick wall (
9"
) with corrugated steel sheet as roof.
I do not want to use brick foundation for the 2nd garage. Instead I would like to use RCC beams as foundation.
What should be the size of the RCC beam? Will a beam size of
2 bars of 12mm at the bottom and 2 bars of 10mm at the top
be sufficient, or more/less steel is needed?
Your advice will be most welcome.
Gerard
Tue Sep 22, 2015
Please check with an engineer.
Tue Sep 22, 2015
For garage is a single story building need not for RCC foundation. How ever lay 12'' wide and 9'' high with 6mm ring/ties with 3nos 12mm MS steel bars at bottom and 10mm at top.
Wed Sep 23, 2015
gpeter
Post subject: Thanks for the info.
Thanks for the to-the-point info. Mr. SL Gupta. Your advice is much appreciated.
I prefer concrete foundation over brick because concrete is cheaper in our region. The cost of labor is too high.
Thanks again.
Gerard
3447
labour charges rates
Last answer on 7/4/2020 2:03:37 AM. by
SAGAR
4690
tie beam obsolete
Last answer on 7/3/2020 11:09:31 PM. by
AD
1685
9143
Vinod
1482
Last answer on 9/5/2016 11:51:29 AM. by
2725
Last answer on 12/31/2020 2:19:19 AM. by
S.Krishnan
RG MAURYA
2875
Foundation Brick estimate
Last answer on 7/4/2020 2:12:13 AM. by
Bs Dhiman
Bs Dhiman
1038
Last answer on 1/25/2021 8:28:32 AM. by
Sonu Adak
1866
santosh
1517
sir, which one is better, brick foundation (as illustrated in your site) or trad
Last answer on 3/5/2016 10:07:27 PM. by
Bhupinder Kumar
1842
Foundation -- Urgent
Last answer on 7/29/2014 1:14:27 PM. by
Debojyoti
2840
Bricks
Last answer on 1/16/2013 11:34:07 AM. by
shahidain
3958
Last answer on 7/25/2013 5:11:37 PM. by
LAKWINDER
shahidain
2132
2275
Last answer on 10/26/2015 11:20:10 AM. by
Vinod
1891
foundation type confusion : pls suggest
Last answer on 12/18/2015 11:22:33 AM. by
sushantsah
1681
material requirememt question
Last answer on 12/26/2015 7:41:53 PM. by
sushantsah
2045
Last answer on 4/6/2016 11:43:24 AM. by
zakia sultana
714
Hi sir,I have already make a foundation so I need
Last answer on 7/3/2020 10:30:07 PM. Forum started by
Malik
2636
Pillar
Last answer on 2/24/2022 11:04:22 AM. by
keshavthakur
2117
Curing urgent
Last answer on 2/23/2022 5:17:08 PM. by
Rohit Sharma
Pooja
2335
structure work
mamtagarg
manish agarwal
5145
Pillar foundation
Last answer on 2/1/2022 10:02:34 AM. by
joe kurian
joe kurian
2170
new house
Last answer on 1/5/2022 2:13:15 AM. by
Janette
ananth
2799
building a house
nashir
1974
Construction Agreement
Last answer on 12/21/2021 12:56:56 AM. by
Abhijit
3071
Foundation
kamal
2251
Foundation
Last answer on 12/20/2021 6:20:53 AM. by
Gagandeep
1454
Last answer on 11/13/2021 8:11:49 AM. Forum started by
passwordc
10019
manishkumar
manishkumar
3637
Foundation
Rohit Sharma
2094
Structure proof checking
Arnab Ghosh
2537
Foundation design
DavidFlores18
nithun
2416
Last answer on 5/22/2021 11:37:00 PM. by
mayowa
2449
Saria and cement
Last answer on 3/25/2021 4:28:11 AM. by
ARVIND GOYAL
3625
Wall Thickness
Last answer on 12/31/2020 2:31:58 AM. by
shankar
2648
Last answer on 7/28/2020 12:37:29 AM. by
K M Sendhil
3123
satya
13232
Steel Type
Last answer on 7/4/2020 2:48:38 AM. by
erbharathi
sumit dua
Designing a Foundation
