Raw Material
RCC roof
RCC roof
Tue Oct 22, 2013
Dinesh Bhadu
Topic: RCC roof
I want to build a godwan of 1350 sq. ft. For that i have constructed cement and bricks piller in 10-10 ft distance.. now i want to know the total
raw material quantity and cost ( i.e cement, bajri, concrete and iron saria (rod)
for rcc roof.. i will put barmas above these pilllers. and there is no other partition in godwan... My location is in bikaner rajasthan
Tue Oct 22, 2013
Dear Dinesh
Your query is not clear.
However for a flat roof of 1350 sft with 5'' thick RCC slab and mix is 1;1.5;3 the material is as under.
1. Cement= 135 bags
2. Coarse Sand= 280 cft
3. Bazri = 540 cft.
4 MS Steel= 1700 kg.
The cost is according Rates in your town.
Fri Mar 13, 2020
Thanks for visiting the site.
9893
Last answer on 9/19/2020 12:43:29 AM. by
shaik khaja nayab rasool
rishi
6381
kota Stone Roofing
Last answer on 12/24/2015 4:01:53 AM. by
Anu
3754
Last answer on 1/30/2017 12:00:36 PM. by
2054
Last answer on 2/15/2017 1:14:19 PM. by
Rajkumar
2613
Last answer on 5/26/2016 10:55:05 AM. by
Madhu Ranjan
2033
Last answer on 7/29/2015 12:07:00 AM. by
jeeveeka
6412
RCC Roofing Cost
Last answer on 12/11/2013 11:01:19 AM. by
Praveen Srivastava
2616
Exterior Walls
Last answer on 2/13/2014 11:54:28 AM. by
Ahmed
Ahmed
13756
Last answer on 1/26/2017 11:24:59 AM. by
Madhankumar
upendra
4402
I would like to know How much Minimum maintain the re inforcment spacing in the
Last answer on 12/31/2020 2:22:36 AM. by
Girish
tkalaiva
4366
WHAT IS THE RATIO
Last answer on 12/17/2010 11:24:47 PM. by
santosh kumar
S.BHUPAL RAJU
191901
Last answer on 1/23/2022 3:32:01 AM. by
Bimlendra Jha
25609
CURING TIME FOR RCC ROOF
Last answer on 5/18/2013 1:47:17 PM. by
Rajesh
2260
advise
Last answer on 8/16/2013 1:07:43 PM. by
faroque
3087
Last answer on 1/20/2017 1:58:48 PM. by
3348
Last answer on 3/28/2014 12:26:36 PM. by
Milon J Biswasi
4431
Last answer on 1/7/2017 7:22:09 PM. by
roshan
roshan
1480
Last answer on 8/24/2016 12:13:52 PM. by
19155
Last answer on 7/3/2020 10:47:35 PM. by
Techman
24767
Last answer on 7/4/2020 12:22:02 AM. by
Techman
1971
Marriage hall construction
chandana kumar
2537
Function Hall
Last answer on 6/14/2021 7:48:53 AM. by
Janette
Mark Paraon
4201
Mohan Bhagwat
11105
Last answer on 3/16/2021 12:44:03 AM. by
Mohan
2189
Last answer on 11/19/2020 1:18:18 AM. by
Aamir
2038
Estimate
Last answer on 7/3/2020 10:09:08 PM. by
amzad
amzad
3073
Steel
Last answer on 7/2/2020 10:08:44 PM. by
EvaR
use of tmt bar
sonu.211
1643
work turned out by labour
Last answer on 5/15/2017 1:35:22 PM. by
carola braats
2457
estimate
raj
1762
mohd asif
2992
3606
Last answer on 5/26/2016 3:18:53 PM. by
naresh
1943
Cost of Steel construction
Last answer on 4/22/2016 11:27:17 AM. by
VikasUmate
1613
Last answer on 12/17/2015 2:49:59 PM. by
sushantsah
2136
READY MIX PLASTER
Bimlendra Jha
1865
Last answer on 3/1/2015 8:14:42 PM. by
baskar
2223
zero slump concrete
Malik Usman
ACC Sheet Roofing
