ROOF WATER PROOFING / TANKING
Tue Nov 17, 2009Total posts : 7
Girish
Girish
Topic: ROOF WATER PROOFING / TANKING
One of the major requirement which get ignored in INDIAN construction practice.
We can divide into two major types
Sub Structure Water Proofing
Waterproofing - Roof
- Bentonite Based water proofing
- Liquid applied water proofing
- PVC
- Torch - on Bitumen
- Self Adhesive Membrane
Tue Nov 17, 2009Post  #1
Girish
Administrator
Girish
Post subject: Liquid waterproofing for bathrooms , kitchens an...
Liquid Wtaerproofing for bathrooms, kitchens and other tiled wet areas
Two component synthetic rubber, liquid waterproofing membreane . Which cures to form a resilient fully bonded elastomeric sheet. Tiles can be fixed directly to the cured membrane with tile adhesives. The use of metal lathing vertically is Optional.
Tools Required
Stiff broof, Steel plastering Trowel. and wet film thickness guage.
Surface preparation
All surfaces shoudl be clean and dry. irregularities greater than 3 mm should be removed or filled. masonary walls should be flush pointed or bagged.
All butt joints in gypsum cement boards should be taped with 50 mm reinforced adhesvie tape. All gaps > 6 mm should be filled with mastic selant allowing sufficeint time to cure before applicable of tape of membrane.
Application
Liquid membrane is best applied using a pour and trowel technique
cover the top half of the wall fi4rst. Use and adapted plasterres hawk or pour directly from the bucket onto the wall.
Fro the bottom half of the wall, pour the material directly from the bucket onto the wall or pour onto a clean area at the bottom fo the wall and trowel upwards.
Swipe and twrowel marks are aceptable as long as minimum thickness is maintained. excessive trowel marks will result in high adhesive usage or an eneven tiled surface. do no over work the material after it has been applied to the wall.
Always have the draingage pipe installed before the material is applied.
Additional adhesive support from metal lathing applied to walls is recommended.
Wed Nov 18, 2009Post  #2
Mohan
Mohan
Post subject: roof water proofing
provide details  of roof waterproofing and methods to arrest leakages in roof
Wed Nov 18, 2009Post  #3
Girish
Administrator
Girish
Mr. Mohan,
Let us counter first the method to arrest existing leakages on Roof
diff. Reasons
1) Leakages from the join of two diff. slabs
case 1
Both slabs casted simultaneiously.  due to the law of heat during casting generated due to process of cement, the pours developed and result in leakages
Remedial method during construction is using debonding agent between the slabs, screeds
Case 2
Two diff. slabs casted at diff. time interval. here too debonding agent might had been used to make sure both slabs are bonded. and height diff. between two slabs
Solution
the best way is to cut a groove on the slab joint from top (approx. 20 mm) and use liquid polyruthene injected to seal the pours. (quality products available in Sika , Fosroc product range.
Epoxy selaants can be used for huge area.  for being economical. (gun grade)
allthough cementioius materials are avialable  but rather wont be effective as the purpose is to seal the pours developed between slabs which resulting in leakages.
Wed Nov 18, 2009Post  #4
Girish
Administrator
Girish
Leakages on Roof.
Ultimate worst case is leakages direct from the slab surface, which is due to poor construction methodology adapted.
generally leakages occur on roof - from the joints
it can be joint of two diff. slabs, joint between column and slab, wall and slab
Good construction practices can counter this  worst nightmare for any house holder
Leakages from Roof
- Use  of  a liquid applied membrane which have the property of debonding and waterproofing between the slab and the roof screed.
- Proper overlapping on self adhesive membrane / torch applied membranes.
- Flashing
Wed Nov 18, 2009Post  #5
Girish
Administrator
Girish
Technical way to arrest leakage between two diff. slabs at diff. height
cast a slab above the jont  and water proof it with membrane
Mon Mar 19, 2012Post  #6
Shridharan
Shridharan
Post subject: Water-proofing for new constructions
Hello Girish,
I am in the process of constructing my house in Pune and looking into proper ways for effective water-proofing. I have received following suggestions from one of my friends in this field & I need your opinion about it.
Option 1: BRICK BAT COBA 6" THICK AS PER SLOPE
Option 2: For flat surfaces - 3 mm thick moply reinforced polyster 4 Kg. gravel finish mat - Atatic polypropline membrane, Preferably - Texa india Ltd. For Sloping surface (a) water proofing membrane Moply FV 3mm preferably - Texa India Ltd (b) P & L of shingles with LPG torchon application for asthetic look
Option 3: Same as option 2 but with equivalent products from Pidilite / Dr FIXIT
Pls reply asap.
Mon Mar 19, 2012Post  #7
Girish
Administrator
Girish
Post subject: Roof water proofing specifications
Considering the Hot climate in India,  we must consider using polystrene insulation on roof tops  and even between two layers of outer block wall.
this guarantee the temperature resistance and save your money in long term on air condition and help you keep your house cool.
A general specification for roof water proofing specially in hot climate like ours is as below
Membrane - flexible puncture resistant , bilogical and chemical resistant high performance reflective roof water proofing membrane cobinaing a spcial high density polythylene composite carrier film and a flexible self adhesive rubber/bitument compound
solar shield
solar shield shall be heavily textured aluminium sheet thickly coated ont eh udnerside with a self adhesive rubber/bitumen compound
Thermal insulation
Thermal insulation shall be either moulded/expanded polystrene or moulded extruded polystrene closed rigid foam board self fnishing. minimum density 32 kg / m3
Screeding
The roof surface to be water proofed shall first be rendered to falls and slopes by screeding.
The rcc surface shall be cleaned of all loose materials dirt, dust etc and 1:3:6 pcc screed of min. thickness 50 mm thickness shall be laid to falls and slopes as required and integrally finished smooth by trowelling.
the screed then be cured and dried. at corners 40 x 40 mm pcc (1:3:6) angle fillet shall be provided and cured.
Membrane application
Two layer built up roofing shall be fixed in accordance with the propreitary manufactures printed recommendations.
the stubstrata shall be dry and prepared to receive treatment.
Primer shall be applied as per mfg. recommendations
All laps shall run parallel to the slop in the roof and joints staggered with 100 mm side and 150 end laps.
second layer shall be laid in lengths not exceeding 8 mtr.
The grooves shall be sealed with approved tropical grade mastic sealtn or covered by snap on powder coated aluminium beading.
Sealants
Bituminous mastic shall be used for moulding into fillets. collars and tapes for sealing around pipes and irregularities
cold applied rubber bitumen mastic compound good for even trowel application.
mastic shall be of grade suitable for hot climate
polyruthane gun grade selant which cures with atmospheric moisture to form a flexible
water proof seal shall be used for flashing
Roof finishing.
The roof areas shall be covered with cement tiles
3163
APP membrane
1959
3968
water proofing of water tank
2768
5056
2237
2829
1729
1934
2483
2187
2376
water tank
3120
2920
Last answer on 4/11/2017 11:10:57 AM. by S L Gupta (Civil Engg). Forum started by vinu
1844
7233
2 lakh litre water tank
6272
Water Tank Quality
23
27
Preventive
Vastu for Water Tank
Damp
Damp Proofing
Protect
