Ground work
ROOFING
ROOFING
Sat Apr 11, 2015
mohit
Topic: ROOFING
IS POLY CARBONATE MULTI WALL ROOFING SHEETS GOOD FOR SHEDS IN SCHOOL. PLEASE LET ME KNOW IF THEY ARE HEAT RESISTANT OR PLEASE SUGGEST SOME GOOD ROOFING MATERIAL FOR SHED FOR HEAT RESISTANCE AS IT HAS TO BE LAYED IN SCHOOL ???
Mon Apr 13, 2015
dear Mohit
there are many types of roofing sheet
1upvc roofing
2 Polycarbonate roofing
3 PVC roofing
4 asbestos roofing
Collect the description/ detail specifications of these materials and select the good one.
Mon Apr 13, 2015
Dear Mohit,
What is the purpose of your shed in school. Is it parking, or is it assembly hall, or any other purpose. please explain first.
Wed Apr 15, 2015
mohit
it is for a baby crunch where small babies of 2-3 yrs will be playing all the time
Ground work-Construction Questions (40)
8420
Roof Beam crack
Last answer on 7/3/2020 11:35:51 PM. by
Arun
2850
Last answer on 7/23/2013 11:24:40 AM. by
g madhusudan
JANCYSABU
2371
Roof construction
Last answer on 9/7/2013 7:13:22 PM. by
aliceria
2158
Last answer on 12/26/2014 1:00:45 PM. by
Last answer on 1/23/2022 3:40:26 AM. by
Last answer on 12/26/2014 12:58:07 PM. by
Roof leakage
Last answer on 2/25/2013 11:42:01 AM. by
Last answer on 10/6/2015 8:18:34 PM. by
sira
2054
Last answer on 2/15/2017 1:14:19 PM. by
Rajkumar
4647
Last answer on 11/4/2021 8:45:13 PM. by
Prem Kant Mishra
Last answer on 6/7/2017 12:17:49 PM. by
Prem Kant Mishra
12251
Last answer on 1/18/2013 3:22:15 PM. by
gnyoganarasimhan
selva
2352
laying of roof
Last answer on 7/4/2020 2:11:52 AM. by
rohit
3271
Roof Concrete Strength
Last answer on 10/12/2014 8:43:10 PM. by
Jahankumar
1875
Last answer on 8/9/2017 12:11:12 AM. by
Saurabh Agarwal
2609
roof thickness
Last answer on 2/26/2022 9:17:15 AM. by
gautam kumar
1555
Last answer on 6/7/2017 12:20:58 PM. by
Sandeep Vidwans
1303
Last answer on 5/21/2018 3:33:47 AM. by
VivekC
RAJAT BANGA
2106
Last answer on 5/25/2018 12:47:44 AM. by
Raghavendra
1280
if the room top not toching the roof then it is considered as room
Last answer on 10/30/2017 11:59:46 PM. by
div
2995
Karan
8159
software
Vaasku
sco4666
sagar suryawanshi
2730
Manish Singh
1833
lanterns
ARVIND GOYAL
3133
false ceiling
sabita laskar
2245
about construction
simran
1786
lowz
4153
Cement Coba
Last answer on 12/21/2021 8:15:49 AM. by
Prasenjit
3076
Water Harvesting System
sunny420
1676
Robert
1758
water tank
rodmotall4
sadanand
2058
sumit
1760
jitendra kumar
1634
Pool construction cost
Erling
Shardul
1994
sanyindias
2738
Regarding roof beam
Amit Kumar
Fire Stair case
mvxmanazxmfsm
tejas
2645
MOHD WAKEEL
2371
super structure
anil kumar
Aluminum Roof
Asphalt Shingles Roofing
Wood Roof Shingles
